Optimizing Sawtooth Wave Generator: Understanding Voltage and Amplitude
  • Thread starter Thread starter Bassalisk
    Generator Wave
In a sawtooth wave generator circuit, with Vcc at 15V, a voltage drop across Re of 2.7V, and a saturation point of Uce at 0.2V, the maximum voltage across the capacitor can be calculated as 12.1V. The transistor will enter saturation when the capacitor is full, but the circuit typically operates by discharging the capacitor before it reaches maximum amplitude. Adjusting the frequency of the impulses can influence the amplitude, but this is not the standard use of the circuit. Instead, the charging rate of the capacitor should be modified by adjusting R1 to achieve a desired frequency. This understanding confirms the correct approach to optimizing the sawtooth wave generator's performance.
Bassalisk
http://pokit.org/get/f118bc654187e429ec1bb489e1eb3a38.jpg
Suppose we have a sawtooth wave generator, like in the picture.
I have a fairly simple question:
If let's say Vcc is 15V, and let's say voltage drop across Re is 2.7V, and saturation point of Uce is 0,2 V. Provided that the period between impulses are long enough, what will happen when capacitor is full? Transistor will go into saturation right?
Or another way to put it, will my MAXIMUM(allowed) amplitude, or voltage across the capacitor be:
15-2.7-0.2=12.1 V?
And I can choose my amplitude by adjusting the frequency of those impulses?
Yes, that is right.
That is not how this circuit would normally be used, though.
Ideally, the lower transistor's base would get a new pulse to discharge the capacitor just before the sawtooth wave reached maximum amplitude.
If you wanted to use a different frequency, then you would adjust R1 to give a different charging rate for the capacitor.
vk6kro said:
Yes, that is right.
Understood. Thank you. Needed somebody to confirm my thoughts.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
