Determine the velocity at which the bullet-block system hits the ground.
The discussion focuses on calculating the velocity of a bullet-block system upon impact with the ground. A bullet with a mass of 0.0020 kg traveling at 300 m/s strikes a 3.0 kg block of wood positioned 2.0 m above the ground. The final velocity of the system is determined using the equation (m1v1 + m2v2) / Mtotal, resulting in a velocity of 0.2 m/s. The participants also discuss the use of kinematic equations and the Pythagorean theorem to analyze the motion, emphasizing the importance of both horizontal and vertical components in the calculation.
  • Understanding of momentum conservation principles
  • Familiarity with kinematic equations (e.g., Vfinal = at + Vinitial)
  • Knowledge of the Pythagorean theorem
  • Basic concepts of projectile motion
  • Explore advanced applications of momentum conservation in collision scenarios
  • Learn about projectile motion analysis, including angle of impact
  • Study the effects of air resistance on projectile trajectories
  • Investigate the use of simulation tools for visualizing bullet-block dynamics
Physics students, engineers, and anyone interested in understanding the dynamics of collisions and projectile motion in real-world applications.
tawko
1. A bullet of mass 0.0020 kg and traveling at 300 m/s strikes the center of a 3.0 kg block of wood which is sitting on a fence post. The block of wood is 2.0 m above the ground.
I got the velocity using the eq (m1v1 + m2v2)/Mtotal = 0.2 m/s [correct if incorrect please]
I then got the horizontal distance by finding time and using x = v*t
Determine the velocity at which the bullet-block system hits the ground. Be sure to include an angle.
2. a^2 + b^2 = c^2 Vfinal = at + Vinitial Xfinal = 1/2at (m1v1 + m2v2) / Mtotal
3. I figured this would involve a right triangle, so I tried solving for the length of the sides. I believe this is where I went wrong. The height of the triangle is 6.272 because i used Vfinal=at+Vinitial, 9.8(.64)+0. I then used the Pythagorean theorem but the answer seemed strange. Thanks.
You did it right as far as I can tell, though you don't need the horizontal distance for anything (don't give yourself more work than necessary). By legs of the right triangle, you mean the horizontal velocity and the vertical velocity, right? If so, you're good. :)
  • · Replies 33 ·
