Register to reply
Detection of AC voltage
by satya77
Tags: detection, voltage
Share this thread:
satya77
#1
Jan25-12, 12:35 AM
P: 39
Hi,
i wanted to control one of my home appliances basically to switch it off after some time (as of now 10mins). i got stuck up at the first step itself where i want to know whether the switch is ON i.e. i wanted to detect whether AC input is on. So my basic question is how to detect a 230v 50hz AC signal and based on the presence of the ac signal i can start some 555 timer circuit and control the switch. i wanted a very low cost circuit i thought of some 230v relay, can i use it?
Thanks in advance,
regards,
Satya
Phys.Org News Partner Engineering news on Phys.org
Amazon worker piloted drone around Space Needle
Five next-generation technologies for positioning, navigation and timing
Hoverbike drone project for air transport takes off
Kholdstare
#2
Jan25-12, 02:55 AM
P: 390
Yeah you can use a relay. But make sure you ground your stuffs properly.
Relay has pin configurations which will tell you which two pin is stuck together when its ON or OFF. You can use multimeter set to ac to detect ac.
berkeman
#3
Jan25-12, 11:04 AM
Mentor
berkeman's Avatar
P: 40,658
Quote Quote by satya77 View Post
Hi,
Thanks in advance,
regards,
Satya
It doesn't sound like you have much experience working with AC Mains circuitry. You need to find some pre-made modules that you can use for this appliance switching application. The shock and fire hazards are too great for you to be trying to home-brew a circuit and build it.
Look at Appliance Switch Modules like these:
http://www.google.com/search?sourcei...ll0&aqi=g3g-v2
Register to reply
Related Discussions
Figuring out voltage across resistor and current in loop given initial voltage input Engineering, Comp Sci, & Technology Homework 2
Interpret Voltage-time graphs to relate the ouput voltage of a piezoelectric crystal Electrical Engineering 7
Node voltage Analysis with voltage controlled voltage source Engineering, Comp Sci, & Technology Homework 4
S4 helix of voltage-gated channels is the voltage sensor of the channel Biology 1
