| New Reply |
Does Boric Acid Expire ??? or become B2O3 after 5-10 years on its own??? |
Share Thread | Thread Tools |
| Feb6-12, 01:25 PM | #1 |
Hi,
I have had some Boric acid (99.9%) bought a very long time ago... The expiry date was in 2006... I have used it recently and it is as if it's pure B2O3. Is that even possible??!! How could it be???! or is there something I am missing? The experiment I had done was heating some of this Boric acid along with certain glass modifiers (Na2O and PbO) and the density as well as other optical properties of resulting glass are as if I have used B2O3 in the batch. There hasn't been any weight loss associated with the decomposition of Boric acid either! thanks in advance... |
| Feb6-12, 05:30 PM | #2 |
When kept at room temperature Boric Acid should last forever. Sometimes though the term "Boric Acid" can be applied to more than one chemical so you should check the label and see what the chemical formula on it says.
http://en.wikipedia.org/wiki/Boric_acid |
| Feb6-12, 06:18 PM | #3 |
its Analytic grade H3BO3...
It has been at room temperature in a poorly sealed plastic container. |
| Feb7-12, 02:05 AM | #4 |
Admin
Does Boric Acid Expire ??? or become B2O3 after 5-10 years on its own???To answer directly your question: no, it won't expire nor change to B2O3, it is quite stable. |
| New Reply |
| Thread Tools | |
Similar Threads for: Does Boric Acid Expire ??? or become B2O3 after 5-10 years on its own???
| boric acid | Chemistry | 2 | ||
| How to convert boric acid to boric oxide | Biology, Chemistry & Other Homework | 5 | ||
| Boric Acid Esters | Chemistry | 8 | ||
| Boric acid used to provide heat protection? | Materials & Chemical Engineering | 1 | ||
