Finding Binomial Co-efficient from pronumerals
  • Thread starter ukee1593
  • Tags
    Binomial
In summary, the problem involves finding the value of (a/b) in its simplest form when the coefficient of x^8 is zero in the expansion of (1+x)(a-bx)^12. Using the binomial expansion formula, the value of r was found to be 7 and 8. After substituting these values and simplifying, it was determined that a/b = 5/8.
ukee1593
I'm asked to find (a/b) in the simplest form if the co-efficient of x^8 is zero in the expansion of:
(1 + x)(a - bx)^12
Binomial expansion formula ... (a + b)^n = Sum of r --> n (r = 0) (nCr)(a^(n-r) * b^r
I figured that x^8 could be achieved from two possible situations ...
either 1 * the expansion of (a - bx)^12 or x * the expansion of (a - bx)^12
I found the value of r at both these points by looking for the value of r that makes bx^r = x^8 and x*bx^r = x^8. This I found to be r = 7 and r = 8. Then I wrote as:
(12C7) * (a)^5 * (-b)^7 + (12C7) * (a)^4 * (-b)^8 = 0
Then I get stuck as I cannot seem to get values for a and b from this.
Can anyone help me?
Problem solved ...
First of all, note my error in the last line
Should be:
(12C7) * (a)^5 * (-b)^7 + (12C8) * (a)^4 * (-b)^8 = 0
The negative b on the (-b)^7 comes out the front as it is an odd power ... The other negative cancels out
-(12C7) * (a)^5 * (b)^7 + (12C8) * (a)^4 * (b)^8 = 0
throw the negative section over to the other side of the equals sign ...
(12C8) * (a)^4 * (b)^8 = (12C7) * (a)^5 * (-b)^7
then evaluate
=> (495)*(a^4)*(b^8) = (792)*(a^5)*(b^7)
start cancelling
=> (495)*(b) = (792)*(a)
divide to each side
=> 495/792 = a/b
=> a/b = 5/8
which is correct according to the answers.
1. What is a binomial coefficient?
A binomial coefficient is a mathematical term used in binomial expansions, which represent polynomial equations with two terms. It is used to determine the number of ways to choose a certain number of elements from a larger set.
2. How do you calculate a binomial coefficient?
The binomial coefficient can be calculated using the following formula: nCk = n! / (k!(n-k)!), where n is the total number of elements and k is the number of elements being chosen.
3. What is the significance of finding binomial coefficients from pronumerals?
Finding binomial coefficients from pronumerals allows us to generalize the calculation for any given set of elements, rather than having to calculate each specific case individually.
4. How can binomial coefficients be used in real-life applications?
Binomial coefficients have various applications in fields such as statistics, probability, and combinatorics. For example, they can be used to calculate the probability of certain outcomes in games of chance or to analyze voting patterns in elections.
5. Are there any other methods for finding binomial coefficients?
Yes, there are other methods such as using Pascal's triangle or using the combination function on a calculator. However, the formula for calculating binomial coefficients from pronumerals is the most widely used and efficient method.
