Circumference of a circle in Poincare Half Plane
The discussion focuses on calculating the circumference of a circle in the Poincare Half Plane, specifically a circle defined by the equation x² + (y-b)² = b² - 1. The user correctly identifies that the radius in the Poincare metric is given by (1/2)ln((b+r)/(b-r)) and attempts to use the arclength formula to derive the circumference. However, the user realizes that their computed circumference, C = 2π√(b²-1), matches the Euclidean circumference, indicating a misunderstanding of the Poincare metric's implications on curvature and distance.
  • Poincare Half Plane model
  • Understanding of geodesics in hyperbolic geometry
  • Knowledge of arclength formulas
  • Basic calculus for evaluating integrals
  • Study the properties of hyperbolic geometry and the Poincare metric
  • Learn about the differences between Euclidean and hyperbolic circumference calculations
  • Explore parametrization techniques in hyperbolic geometry
  • Investigate common pitfalls in applying the arclength formula in non-Euclidean spaces
Mathematicians, geometry enthusiasts, and students studying hyperbolic geometry who seek to understand the nuances of calculating distances and circumferences in non-Euclidean contexts.
demonelite123
i am trying to figure out how to calculate the circumference of a circle in the Poincare Half Plane. I know that vertical lines are geodesics so using the arclength formula, the distance between 2 points [itex](x_0, y_0) and (x_1, y_1)[/itex] on a vertical line is [itex]ln(y_1/y_0)[/itex]. Thus, if i have a circle centered at (0, b) on the y-axis with radius r, then the radius of the circle using the Poincare metric will be [itex]\frac{1}{2}ln(\frac{b+r}{b-r})[/itex].
I want to find the circumference of the circle [itex]x^2 + (y-b)^2 = b^2 - 1[/itex] so i parametrize [itex]x = \sqrt{b^2-1}cos(\theta), y = b + \sqrt{b^2-1}sin(\theta)[/itex]. I then use the arclength formula and get [itex]C = \int^{2\pi}_0 \frac{\sqrt{b^2-1}}{b+\sqrt{b^2-1}sin(\theta)} d\theta[/itex]. I have the extra factor of [itex]y = b + \sqrt{b^2-1}sin(\theta)[/itex] on the bottom since I am using the Poincare metric. This evaluates to [itex]2\pi\sqrt{b^2-1}[/itex] which i know shouldn't be right since the circumference of this circle using the regular euclidean metric is also just [itex]2\pi\sqrt{b^2-1}[/itex]. can someone help me figure out what went wrong here?
Why do you think your answer is wrong? Can you say more? Justify it better?
  • · Replies 0 ·
  • · Replies 29 ·
  • · Replies 24 ·
