| New Reply |
High pass filter and low pass filter question? |
Share Thread | Thread Tools |
| Feb26-12, 12:29 PM | #1 |
You have a series circuit consisting of a ac power supply, a 1150.0 ohm resistor and a 144.0 nF capacitor. If the circuit is configured as a low pass filter, what frequency will cause the gain to be 0.25?
Formula Gain = Vout / Vin = R / [R^2 + (1/ωC)^2]^1/2 Solution Plugging in R=1150 ohms C=144*10^-9 F to find a value for ω And then using ω=2 π f I got f= 0.05223Hz which is wrong. Also what will be the formula for high pass filter? Please help! |
| Feb26-12, 12:47 PM | #2 |
Mentor
Show your calculations for finding ##\omega##.
| Feb26-12, 04:29 PM | #3 |
2. Gain expression for high-pass would be ωRC/√(1 + ω2R2C2) |
| Feb26-12, 06:58 PM | #4 |
Calculations for ω
ω=2∏f The formula by prof has given me is Gain = Vout / Vin = R / [R^2 + (1/ωC)^2]^1/2 for a low pass filter. 0.25 = 1150 / [1150^2 + (1/ω*144*10^-9)^2]^1/2 My bad. I had a calculation mistake previously. I did it again and this time I solved it to get ω=1.5592*10^3 Using ω=2∏f, f=248.15 Hz. Which is still wrong... :( I'm confused as to what frequency they are asking me for. Is the this frequency just plain ω? Am I making a mistake by calculating f=ω/2∏? |
| Feb26-12, 11:39 PM | #5 |
Recognitions:
| Feb26-12, 11:48 PM | #6 |
Recognitions:
Then determine for yourself its transfer function, and sketch it. That way, you can't go wrong. |
| Feb27-12, 02:50 AM | #7 |
But the formula your prof gave you, if he really did, is still wrong. Sketch the diagram for the low-pass circuit, write a summation of currents into the node at the capacitor. Then you can determine the right formula yourself. Don't just accept a formula from someone else, derive it for yourself, or you really won't learn what you need to. BTW my answer is about 3724 Hz, is that what your prof got? |
| New Reply |
| Thread Tools | |
Similar Threads for: High pass filter and low pass filter question?
| transforming a low pass filter to a band pass and low pass filter | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Transforming a low pass filer to a high pass filter | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Filter DC offset - apply High-pass filter (in time-domain or frequency domain?) | Electrical Engineering | 3 | ||
| High Pass filter & Low Pass Filters features | Engineering, Comp Sci, & Technology Homework | 1 | ||
