Qube root of 2, zero of second order polynomial
jostpuur
How do you prove that there does not exist numbers a,b\in\mathbb{Q} such that
<br /> 0 = a + b\sqrt[3]{2} + \sqrt[3]{2}^2<br />
The polynomial X^2+aX+c will have to divide X^3-2 in that case.
I think we only know that X-\sqrt[3]{2} must divide X^2+bX+a.
X^2+bX+a doesn't need to divide anything.
I see.
I have tried to read Galois theory earlier, and now I started remembering stuff. :cool: (Although that Wikipedia-page didn't help much...)
The knowledge that X^2+bX+a must divide X^3-2 is one possible way to the proof, but actually the idea of the minimal polynomial can be used in more primitive ways too. For example, simply write
<br /> X^3 - 2 = (X^2 + bX + a)(X - b) + (b^2 - a)X + ab - 2<br />
and proof starts to appear.
What is the logic behind this statement? From a false premiss you can of course deduce anyhing you like, but I assume that is not your intended logic here. When it comes to minimal polynomials and such, the general result is usually the other way around: if g(x)\epsilonQ[x] has a root \alpha, then the minimal polynomial of \alpha divides g.
If the cube root of 2 satisfies a quadratic polynomial, then x3-2 is NOT the minimal polynomial (since there's a lower degree polynomial that gives us zero). So there are two possibilities
1) The minimal polynomial is degree 1 - obviously false
2) The minimal polynomial is degree 2 - in this case, the quadratic polynomial we have must be the minimal polynomial
With the anti-thesis assumption the X^2+bX+a becomes the "new" minimal polynomial. Or at least that's one way to get to the proof. See my reponse #5 to see the essential. There are several ways to complete the proof then.
