New Reply
Wind Force is Equal?
Share Thread Thread Tools
Mar15-12, 08:12 AM   #52
Where does the energy go? He moves with the same speed through the wind, so he displaces the same amount of air, there is no friction in the bicycle so the only force is of the wind and since the drag factor is the same, he is pushing the earth with the same force for the same amount of time in both cases, F=ma and the earth gets the same acceleration. Should the earth's energy increase just because the cyclist is moving when he applies the force? But what about a=F/m?
Mar15-12, 09:37 AM   #53
Recognitions:
Homework Helper Homework Help
Quote by chingel View Post
Where does the energy go? he is pushing the earth with the same force for the same amount of time in both cases
Same impulse equals same change in momentum, so from the riders frame of reference, on the windless day the earth surface speed increased from 25 kph to 25+ΔV kph, and on the windy day from 5 kph to 5 + ΔV kph. Assuming the earth only rotates faster due to surface speed increase, the energy change is relative to 1/5 m (V12 - V02) = 1/5 m (50 x ΔV) on windless day and = 1/5 m (10 x ΔV) on windy day. So there is 5x energy added to the earth on the windless day versus windy day (if the force x time are the same).
Mar15-12, 11:34 AM   #54
Recognitions:
Gold Membership Gold Member
Let's get it right. Energy / work is Force times Distance not time. Ft is momentum change!
Mar15-12, 01:25 PM   #55
This is not a simple question at all.
Flow and turbulence can be very complicated, in addition we’re dealing with a human body hence our picture becomes very clouded.
In cases such as this one I’ll try to reduce the variables as much as possible. So I imagine comparing the energy needed for my car to be parked up in a 25 kph wind and then the same car to drive 25 kph on a windless day. I’d be p*** off if I had to refill fuel just for standing still. So what’s the difference if the forces are the same?
I’d imagine that if we have to ignore tire friction, engine heat etc then when driving, the fuel energy gets transferred to higher air vortices in front and behind the car. This higher turbulence will eventually end up in a higher air KE, ie heat up the surrounding air.
I cannot see how mass comes into this, unless you mean the mass of air involved.
Edit: I just realised I’ve left out another subtle but important factor. When I’m driving the car it’s the car which is causing the turbulence, when parked the wind provides the energy.
Mar16-12, 07:13 AM   #56
Quote by rcgldr View Post
Didn't quite catch that. How did you get that the energy change is relative to that?
Mar16-12, 07:21 AM   #57
Recognitions:
Assume that all the energy change in this situation is angular, and v is surface velocity of earth relative to rider, and that earth is a solid uniform sphere.
E = 1/2 I ω2
for solid uniform sphere: I = 2/5 m r2
ω = v/r
E = 1/2 (2/5 m r2) (v/r)2 = 1/5 m v2
The increase in energy = (1/5 m) ((v + Δv)2 - v2) = (1/5 m) (v2 + 2 v Δv + Δv2 - v2) ~= 1/5 m 2 v Δv
Mar16-12, 09:50 AM   #58
OK, I follow that now, the earth seems to have more energy because the rider is going faster, but according to a different frame from the rider's frame, let's say in a frame originally at rest to the earth before the bicycle started riding, where does the energy go?
Mar16-12, 03:11 PM   #59
Into the air. On a windless day he definitively adds KE to the air. By going slowly upwind he eventually even removes KE from the air. But he cannot use that energy. It is converted into turbulence.
Mar16-12, 05:22 PM   #60
Recognitions:
In a frame originally at rest to the earth before the bicycle started riding, where does the energy go?
Keep in mind that the rider is generating 5 times the power into the system on the windless day versus the windy day, the force at the rear tire is the same, but the speed on the windless day is 5x that of the windy day. Also the frame of reference initially at rest with the earth, is inertial and doesn't accelerate with the surface of the earth.
So the impulse to the earth is the same, resulting in the same increase in velocity and energy. On the windless day, energy is added to the air by the rider. On the windy day, energy is extracted from the air (and transferred to the earth). Total energy of this system is conserved (assuming no losses), so after 1 hour, the total kinetic energy is increased by the decrease in rider potential energy, which is 5x more on the windless day. In this frame, the total energy change of the earth is the same on both days. On the windless day, the rider provides all of the energy added to the earth and wind. On the windy day, the rider supplies only a fraction of the energy added to the earth and the slowing the wind provides most of the energy added to the earth.
Mar16-12, 05:26 PM   #61
Recognitions:
Quote by A.T. View Post
To say that he removes KE is to ignore the fact that the mean velocity of the air molecules is not changed - but this is only locally for a short time.Any interaction with the air is, essentially, a loss mechanism - to my mind.
Mar16-12, 07:35 PM   #62
Power is defined as force times velocity, it states in the problem that the force is the same for both situations, so therefore power is greater when the bike is going 25 km/h than when the bike is going 5 km/h.
Energy is equal to power times time when power is constant (which i think is assumed for this problem) and the problem states that they both are riding for one hour, so the bike that has the higher power, the one that's going 25 km/h, also uses more energy in the time frame.
I don't understand why there's such a debate over this :/
(this is my first post :D)
Mar16-12, 08:27 PM   #63
Recognitions:
Quote by sophiecentaur View Post
To say that he removes KE is to ignore the fact that the mean velocity of the air molecules is not changed but this is only locally for a short time.
Forces don't vanish, so the forward force exerted by the rider to the air results in some net residual velocity, probably in the form of an impulse that ends up being dispersed into an ever increasing volume of air, but the magnitude and direction of that impulse will remain the same until opposed by some other force.
From the frame that is initially at rest with the surface of the earth, on the windy day, the wind is allowing the rider to generate the same force at 1/5th of the speed of the windless day, only requiring 1/5th the power from the rider while the earth still ends up with the same amount of energy on both the windless and windy days. So on the windy day, slowing down the wind provides most of the energy being transferred to the earth.
Simpler still, change the situation on the windy day so that the rider just stands in place without any movement relative to the earth's surface (zero energy generated by the rider). In this case the earth still gains energy, and all of the energy gained by the earth is due to the wind being slowed down. Momentum is conserved, so any gain in momentum of earth is offset by a loss in momentum of the wind.
Mar17-12, 06:46 AM   #64
OK thank you I follow that now.
Mar20-12, 02:03 PM   #65
D H
Mentor
A bit late, but just in case anyone reading some of the posts in this thread starts to wonder whether some PF mentors are complete idiots, let me reassure you.
I am a complete idiot. At least in this thread.
Mar21-12, 06:05 AM   #66
Quote by D H View Post
It's reassuring to see that a PF mentor can get something wrong, but it's even more reassuring to see that a PF mentor can admit a mistake with so much candour. Thanks.
Mar21-12, 11:48 AM   #67
The scenario allegedly provided by a Ph.D. was very poorly articulated therefore, it has resulted in a myriad of answers based upon individual impressions of that which was meant by the professor’s use of the term “effort”. “Effort” is a relative term to humans, as one individual may deem a required effort as considerable whereas another may deem the same requirement somewhat insignificant. Humans possess various states of physical conditioning, some with seemingly unending stamina, others with exceptional strength, while others are the 90 pound weaklings that sway by manner of a stiff breeze.
When we think of “effort”, our impression is typically that of an “overall effect” therefore it takes in one’s impression of how hard it was to pedal (the force required) as well as one’s impression of how draining it was (energy required per a distance traversed) or (energy required per pedaling for a given time duration), none of which was specified by the professor. The professor receives an ‘F’ for his poorly articulated scenario.
As an ardent bicyclist and having just recently pedaled 100 miles on this past March 14, 2012 (half of which was into the wind as I headed westward), I can convey from firsthand experience that pedaling into the wind is far more draining to traverse a given distance compared to traversing the same distance via still air and conversely, a tailwind on the return trip most definitely reduces the energy requirement to traverse the same distance. Since all bicycle “rides” involve traversing some manner of distance––typically a predefined favorite route––one is not interested in how much energy is used to pedal against the wind at a lower speed rather, they are only interested in the amount of energy required to traverse the desired distance by manner of pedaling.
Conversely, only those on stationary bicycle trainers are concerned with the amount of energy required while pedaling, as all the pedaling in the world leaves them right where they started. LOL
Mar21-12, 12:37 PM   #68
Quote by Gnosis View Post
It's true that "effort" might mean either force applied or work done (i.e. energy expended). Since the time duration was specified (one hour in both cases), it's reasonable to conclude that "effort" here means work done.
I'm sure all will agree that going against the wind requires more power than going at the same speed with no wind: in the first case, the resistance from the air is greater. In the given question this is not the case: pedalling for an hour at 5 km/h does not require as much energy as pedalling for an hour at 25 km/h, if in both cases the air offers the same resistance.
New Reply
Tags
force, friction, headwind, wind
Thread Tools
Similar Threads for: Wind Force is Equal?
Thread Forum Replies
wind scaling and increasing wind speed for wind tunnel problem Mechanical Engineering 3
Wind Power Vehicle Traveling Down Wind Faster Than The Wind General Physics 305
Equal and Opposite Force Help General Physics 5
Normal Force and Force of Gravity: When and why are they equal? Introductory Physics Homework 5
Centrifugal Force: Are these equal? Introductory Physics Homework 2
