New Reply
Fastener spacing and sealing with o-rings
Share Thread
Mar22-12, 07:20 PM   #1
I have to seal a spherical container comprised of 2 hemispheres joined together with a bolted flanged connection. I plan on using o-rings to seal the liquid (water) in. The problem I am having is finding the minimum number of bolts required to compress the o-ring and seal the joint. Can anyone point me in the right direction? Any help is appreciated.
Thanks
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar22-12, 09:16 PM   #2
How much pressure do you anticipate? What is the area of your flange surface?
Mar22-12, 09:38 PM   #4
I'll check that link out. To answer your question, the internal pressure is about 125 kPa and the flange area is 0.061 m2.
Mar22-12, 10:40 PM   #5
just curious, why do you need the minimum amount of bolts?
for theory?
for cost?
for weight?
Mar27-12, 08:52 PM   #6
huntoon,
I am mostly going through the through the calculations for theory as it is for a school project. I was just trying to factor in the force required to keep the o-ring in compression with the internal pressure working to un-seal the joint. Using this I was going to calculate the number of bolts around the bolt circle. Is this not usually done, or is it done by different means? Thanks again for the help
greentlc
Mar31-12, 12:28 AM   #7
A conventional & quite normal engineering approach to this question, would be to select one of the many Standards documents which deal with sealing flanges at various pressures, with appropriately chosen safety factors.
Be aware that your O ring should be only ever subject to minimum compression within it's elastic deformation range. Any O ring supplier can provide charts advising on this. Remember that O rings will almost always be seated in O ring grooves which are also subject to close specification by the O ring suppliers.
Your bolt spacing will probably be commanded by the flange thickness & available surface area to accomodate the bolt heads.
New Reply
Similar discussions for: Fastener spacing and sealing with o-rings
Thread Forum Replies
sigma-rings are closed under countable intersections (sigma-rings are delta-rings) Calculus & Beyond Homework 2
Grade 660 Class A,B,C Fastener Rusted. Mechanical Engineering 0
Polynomial Rings/Fields/Division Rings Calculus & Beyond Homework 9
relationship interatomic spacing or interplanar spacing and grain size Atomic, Solid State, Comp. Physics 5
Need a fastener locking mechanism for #8-32 NC screw. Mechanical Engineering 21
