Flawed Proof: x + y = y in Algebra - Spivak Calculus (1994) Homework
  • Thread starter Thread starter jrdunaway
    Calculus Spivak
The discussion centers on identifying the flaw in a mathematical proof that incorrectly concludes 2 equals 1 by assuming x equals y. The critical error occurs when dividing by (x - y), which equals zero under the assumption that x = y, making the division invalid. Participants highlight that instead of dividing, one should factor the equation to properly analyze the solutions. The conversation emphasizes the importance of recognizing when division by zero occurs and suggests alternative methods for solving equations without losing potential solutions. The thread concludes with appreciation for the insights shared.
jrdunaway
2. What is wrong with the following "proof"? Let x = y. Then
x2 =xy,
x2 - y2 =xy - y ,
(x + y)(x -y) = y(x - y),
x + y = y,
2y = y,
2= 1.
It's obvious that x + y =/= y, but I do not know how to "prove" this, i.e. which proof from algebra is applicable here. My hunch is that it is the Distributive Property?
I honestly am not sure where to start with this. All I can see is that dividing (x-y) out from step 3 to step 4 is what causes the inequality.
welcome to pf!
hi jrdunaway welcome to pf! :smile:
x + y = y,
that's right! :smile:
if x = y, that means that you divided by 0, which isn't allowed
so (if x = y) that step is not valid
x2 =xy,
x2 - y2 =xy - y ,
You mean xy- y2 on the right.
But you still can't divide by 0.
x + y = y,
2y = y,
2= 1.
5*0= 0 and 3*0= 0 so 5*0= 3*0. It does not follow that 5= 3!
x2 =xy,
x2 - y2 =xy - y ,
x + y = y,
What instead should have been done was
(x+y)(x-y)=y(x-y)
(x+y)(x-y)-y(x-y)=0
(x-y)(x+y-y)=0
(factorized out (x-y) from both factors)
(x-y)x=0
So either x-y=0, thus x=y, or x=0
This is common practice when solving quadratics and such. If you end up with x^2+x=0 for example, you don't divide through by x to obtain x+1=0 because then you lose the solution of x=0. What you instead do is factorize into the form x(x+1)=0 which allows you to find all the solutions.
PhysicsForums,
you guys have exceeded my expectations! Thank you! I'll be back soon I'm sure :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
