Why Is Friction Uphill When a Ball Rolls Uphill?
  • Context: Undergrad
  • Thread starter Thread starter azizlwl
    Dynamic Motion
The discussion revolves around the direction of friction when a ball rolls uphill or downhill, exploring the underlying physics principles related to motion, forces, and torque. Participants examine the implications of friction in different scenarios, including the effects of gravity and angular acceleration.
  • Some participants assert that when a ball rolls uphill, the force of friction is directed uphill, opposing the motion of the center of mass.
  • Others present equations of motion for both uphill and downhill scenarios, suggesting that friction acts in a direction that opposes the acceleration of the ball.
  • A participant mentions that the rotation of the ball is anticlockwise regardless of whether it is rolling uphill or downhill, implying that the direction of friction remains consistent in both cases.
  • Some participants express confusion regarding the relationship between the direction of friction and the instantaneous velocity at the point of contact with the surface.
  • A later reply questions the assumptions made about the forces acting on the ball, particularly whether the friction is considered an internal or external force.
  • There is a discussion about the direction of friction in relation to a wound cylinder, with some participants noting that the frictional force may differ based on the context of the problem.
  • Participants also explore the mathematical relationships governing the motion of a cylinder rolling without slipping, attempting to clarify how to determine the direction of the frictional force.
Participants do not reach a consensus on the direction of friction in various scenarios, and multiple competing views remain regarding the relationship between friction, acceleration, and the direction of motion.
The discussion includes various assumptions about the nature of friction, the role of gravity, and the conditions under which the ball or cylinder is rolling. Some participants express uncertainty about the mathematical steps involved in their reasoning.
azizlwl
If the ball were rolling uphill, the force of friction would still be
directed uphill as in FJg. 1O.19b. Can you see why'?
http://img252.imageshack.us/img252/4516/rollingm.jpg
I always assume the friction is always in opposite direction of the motion.
if the ball is rolling down then
a(cm)=(mg sinβ - f)/m and Iα=fr
and since a=rα
(mgsinβ - f)/m=fr^2/I
f is positive from here so when it is rolling down f is upward opposing the motion of centre of mass.
if it is rolling up then
a(cm)=(f - mgsinβ)/m and Iα=-fr
so (f - mgsinβ)/m=-fr^2/I
from here too it is upward.
thank you.
hi azizlwl! :wink:
we can always take moments about the centre of mass
let's do so … the ball in the diagram is accelerating anticlockwise no matter whether it's rolling downhill or uphill …
since the only external torque about the centre of mass is the friction, that must also be anticlockwise in both cases! :smile:
tiny-tim said:
hi azizlwl! :wink:
My assumption is that going downhill the rotation is anti clockwise and uphill the rotation will be clockwise. So the friction must reversed its direction.
By your explanation, it means we have another inclined plane on the left side, where the ball keep rolling up with same rotational direction from right position of the inclined plane..
yes, the rotation will be clockwise, but the angular acceleration will be anti-clockwise
(because this is a freely rolling ball)
so the friction will be in the same direction, whatever the direction of rotation
Sorry i didn't read properly.
It's the rotational acceleration that remains the same uphill or downhill although the direction changes.
Analogy of throwing an object upward, direction changes but acceleration remains.
Doing Physics mental experiment is really a tough for me. Thank you.
Problem with rolling.
Can i use different approach.
Assume No friction as in inclined plane. The instantaneous velocity in contact with the plane is downward so the friction upward. Thus produce torque clockwise.
For the problem https://www.physicsforums.com/showthread.php?t=603360.
Assuming no friction, the instantaneous velocity in contact with the ground is opposite of the force. Thus the friction is in direction of the force.
For uphill, the rotation will be clockwise or uphill thus instantaneous velocity in contact with the plane is downward giving friction in opposite direction that is uphill.
hi azizlwl! :smile:
i'm not sure what you're saying, or what force you're assuming
it doesn't look right, because you're concentrating on the velocity of the point of contact, when the primary consideration is the direction of the acceleration (either linear or angular)
by force, are you still referring to gravity, or is this an extra applied force?
for an "external" applied force, such as a rope or gravity, the direction of friction is opposite the acceleration, but for an "internal" force such as from the engine, it is in the same direction as the acceleration
I just try to find out the direction of friction force which to me it's very confusing.
For instance, a cylinder rolling downhill the friction direction is uphill
For cylinder rolling uphill, frictional force direction also uphill. You have given me the acceleration point view.
For a wound cylinder, the friction is in direction of the force pulling the string (as in https://www.physicsforums.com/showthread.php?t=603360).
Yes I'm concentrating on the velocity of the point of contact so that i will get direction of the friction which is in opposite direction of the motion(i guess it's always true).
but that wound cylinder isn't rolling (on the table), and there's no friction …
azizlwl said:
The frictional force between table and cylinder is negligible.
:confused:
Sorry about the wound cylinder question.
It was second question(repeat problem 11.70 if the frictional force between table and cylinder is negligible.)
11.70
The rope shown is wound around a cylinder of mass 4.0 kg. and I=0.020kg.m2, about the cylinder axis. If the cylinder rolls without slipping, what is the linear acceleration of its center of mass? What is the frictional force? Use an axis along the cylinder axis for your computation?
Solution
Choose left and ccw as positive. Write F=ma=20 +f=4a with f being the friction force at the floor. From τ=Iα=(20-f)(0.01)=0.02(s/0.10) =>a=6.7m/s2 and f=6.8
From the solution given frictional force f is direction of the 20N force. Intuitively it should be opposite of the cylinder motion.
So here i have to figure out how to determine the direction of the frictional force.
Thank you
hi azizlwl! :smile:
no, you have a decimal point wrong somewhere :redface:
20 + f = 4a
20 - f = 20a :wink:
  • · Replies 37 ·
38K
  • · Replies 37 ·
