New Reply
Conservation of Mass Question
Share Thread Thread Tools
May2-12, 07:07 PM   #1
Hi
Just a quick question about Conservation of Mass that I somehow managed to confuse myself:
If I have a vent of constant cross section at steady state, given that conservation of mass means that inlet and exit mass flow rate must be the same, does this mean that, taking the compressibility of gas into account (for this example I'm assuming Ma > 0.3 although unrealistic in real life), this means that the exit velocity must be greater than the inlet velocity (temperature and pressure are the same in inlet and exit)?
Basically my question is (and I know this sounds stupid), conservation of mass holds always even if the gas is compressible?
Thanks
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
May3-12, 10:28 AM   #2
Conservation of mass always holds.
In your example, "steady state" would usually mean that mass (and hence gas pressure) aren't building up between the inlet and the exit.
May3-12, 03:27 PM   #3
Use grams per second as flow rate.
May4-12, 10:29 AM   #4
Quote by olivermsun View Post
Hi
So at steady and the gas is flowing very fast such that it becomes compressed by the time it gets to the outlet (so its density is higher at the outlet than inlet). Keeping P and T known and constant and area as constant, then the gas velocity at the outlet and inlet are related by the inlet density/exit density = exit velocity/inlet velocity? And the ideal gas law can be used to relate the densities (assuming the P and T conditions are ideal enough)?
Thanks
New Reply
Thread Tools
Similar Threads for: Conservation of Mass Question
Thread Forum Replies
β+ decay: voiding conservation of mass or creating something with negative mass General Physics 4
General relativity question on mass conservation integral Advanced Physics Homework 1
Law of conservation of mass question Chemistry 2
question about conservation of energy/mass Classical Physics 2
One question on conservation of mass and energy Introductory Physics Homework 0
