Research in mechanical engineering- what is it all about(just general idea)
Research in mechanical engineering encompasses a variety of methodologies, including both simulation-based and experimental approaches. While simulation work, like using software such as COMSOL, is common, an MS degree may involve a broader range of research activities. Key qualities for success in this field include an inquisitive mindset and attention to detail. The nature of research in mechanical engineering shares similarities with other scientific disciplines, but it is tailored to specific engineering applications. Understanding your interests will help guide your research focus during your MS studies.
Urmi Roy
Research in mechanical engineering-- what is it all about(just general idea)
Hi,
I'm a student of mechanical engineering and I'd like to do an MS degree following my undergrads.
Up till now, I've had experience in only simulation based research i.e. during my final year project, my instructor asked me to to reproduce a biological system on a software called COMSOL and by varying inputs to the model, we could guess how it would behave if such stimuli were applied to the system in real life.
However, if I do an MS degree, will I be doing this kind of work or is research in MS totally different?
The bottom line is that I need to know what research is all about and what qualities I need to have to be a successful researcher.
How is the research in mechanical engineering different from that in mainstream Physics/Chemistry?
Research is research regardless of whether it is in mechanical engineering or physics. The most important qualities you will need are an inquisitive mind and some measure of attention to detail. The research itself can take many forms depending on your research interests and whether or not you are a computational guy or an experimental guy.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
