Energy and momentum conservation
The discussion revolves around the conservation of energy and momentum during collisions between point masses. Participants explore the implications of these conservation laws on the interaction between the masses, particularly in the context of elastic collisions and the geometric aspects of their interaction.
  • One participant questions how energy influences the ability of two masses to interact during a collision, suggesting that if energy were conserved, the first mass would not be able to push against the second mass once their velocities equalize.
  • Another participant asserts that if energy were conserved, the first mass would stop, implying that momentum conservation alone does not account for the interaction dynamics.
  • A different viewpoint suggests that during a collision, the two masses will eventually move together with the same velocity, but questions arise about the timing of their interaction and the implications of energy conservation.
  • One participant introduces the concept of elastic collisions, noting that real-world collisions are not perfectly elastic due to energy being transferred to atomic vibrations, yet energy is still conserved.
  • A paradox is identified regarding the transfer of kinetic energy from one mass to another, particularly when the second mass begins to separate before fully acquiring the first mass's velocity.
  • Another participant highlights the unrealistic nature of a two-particle model, suggesting that real bodies have finite sizes and will deform, affecting the forces exerted during the collision.
Participants express differing views on the relationship between energy conservation and the mechanics of collision interactions. There is no consensus on how these principles operate in the context of the proposed scenarios.
The discussion includes assumptions about idealized point masses and does not account for the complexities introduced by real-world physical properties such as deformation and atomic interactions.
aaaa202
Consider a point mass of mass m going with velocity v towards a point mass also of mass lying still.
Now conservation of momentum allows any combinations og mass times velocities that add to the total momentum before the collision. So for instance ½mv + ½mv would be good. This is where the masses collide until they have the same velocity. For me it makes sense that this would happen since the first mass is not able to push against the other as soon as the mass originally lying still is going faster than the other - which happens infinitesimally later than when their velocities are the same.
However, if energy was to be conserved the above would not hold, since E is proportional to v squared. My question is: How can energy have influence on when our two masses geometrically are able to push against each other or not? - like if energy was conserved in the above they would still be pushing against each other even though the first particle would be slowing down as seen from the second particles frame.
hi aaaa202! :smile:
aaaa202 said:
… How can energy have influence on when our two masses geometrically are able to push against each other or not? - like if energy was conserved in the above they would still be pushing against each other even though the first particle would be slowing down as seen from the second particles frame.
if energy was conserved, the first mass would stop dead
even if the first mass is much heavier, there is still no question of it pushing the second mass if energy is conserved
change to a frame of reference in which the centre of mass is stationary …
if both momentum and energy are conserved, then obviously the velocities simply change places, ie a "perfect bounce"! :biggrin:
okay but let's slow time down and look at what happens. Half time during the collision the two masses both move in the same direction with same velocity. a split second after that the mass originally lying still will have greater velocity than the first. Conclusion: The masses are unable to touch either and thus interact with forces. But if energy is conserved they still do that - how do you explain that?
(1) You are asking about elastic collisions in which kinetic energy is conserved. For 'macroscopic' bodies (i.e. those made up from loads of atoms) collisions are never perfectly elastic. Some of the initial kinetic energy is transferred to increased random vibration of the atoms. But energy is conserved.
(2) I think you've set out a most interesting paradox: how can one body, A, transfer all its KE to another body, B (initially stationary) if, half-way through the process, B starts to separate from A when it's got only half of A's velocity. Hope I've grasped it.
The paradox arises, I think, from your two particle model. Either the particles are touching and exerting forces on each other, or they're not touching, and they go from touching to not touching in an infinitesimal distance. This isn't realistic. In practice the two bodies will have finite size and will deform. They will repel each other (to a greater or lesser extent) throughout the time they're deformed, including after the instant when their centres of mass had the same velocity.
With two (spinless) positively charged particles 'colliding it's even easier to see what's going on; the collision process is one of repulsion over a period of time.
  • · Replies 30 ·
  • · Replies 53 ·
