Finding hamiltonian for spring/pulley problem
  • Thread starter Thread starter Ned Stark
    Hamiltonian
Ned Stark
a light, inextensible string passes over a small pulley and carries a mass of 2m on one end.
on the other end is a mass m, and beneath it, supported by a spring w/ spring constant k, is a second mass m.
using the distance x, of the first mass beneath the pulley, and the extension y in the spring, as generalized co-ordinates, find the hamiltonian
H=kinetic energy+potential
The problem, as stated above, is copied straight from the book, and I am not really sure what the coordinate x describes.
ill call the mass of 2m "M1"
& "M2" is the mass connected to the string from above, and spring from below
& "M3" is the mass hanging from the spring.
In my setup, x is the distance from the pully to M1, and y is the extension of the spring
so the kinetic energy in terms of x and y:
for M1: KE= m(dx/dt)^2
M2: KE= 1/2 m(dx/dt)^2
M3: KE=1/2 m(dy/dt+dx/dt)^2
Then for the system,
KE =3/2 m(dx/dt)^2+1/2 m(dy/dt+dx/dt)^2
I am struggling writing down the potential in terms of x and y
M1 will have only that of gravity, where as the other 2 will also have a spring term.
Can anybody point me in the right direction with these coordinates?
The masses don't have spring potential energy. The spring does. The total potential will consist of the gravitational potential energy of the three masses plus the potential energy of the spring.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
