LM6000 Gas Turbine Outputs/Inputs
The discussion focuses on calculating the efficiencies of a CHP aero derivative turbine, specifically an LM6000 model. The user questions the apparent discrepancy in efficiency, noting that with a heat rate of 8980 kJ/kWh and power output of 43,822 kWh, the expected heat output seems too high compared to the stated electrical efficiency of 39%. Clarifications reveal that kJ/kWh measures fuel consumption, and the efficiency should be calculated by converting to kJ/kWs and taking the reciprocal. Additionally, overall efficiency must account for heat recovery in the CHP system. The user acknowledges a misunderstanding regarding energy and power units, highlighting a need for better comprehension of CHP operations.
kyles
I am doing research and was curioius as to how I would obtain useful numbers for efficiencies from the following information, concerning a CHP aero derivative turbine,
Power KW = 43822
Heat Rate LHV KJ/kWH = 8980
From this, can I say that if I ran the machine for an hour I would use 43,882KWH and receive 109311.54KWH of heat out put [ from, (8980kj/kwh x 43822kwh)*1000/(3.6MJ)) = 109311.54KWH ]
However, when I use the table for running at full load, the electrical efficiency of the machine is 39%. I considered that this may be total efficiency but 39% for a CHP seems way too small, should be closer to 60-70 right?
Which means that I put in 43822KWH/.39 = 112364.1KWH but got out 109311+43882=153193KWH.
As I am sure that this is not an over-unity machine, can anyone show me where I am going wrong?
It's a generator: kJ/kWh is how much heat you need to input for every kWh you get in output. You've got the efficiency equation upside-down!
Hm, why aren't both units in energy then, one's in power. I realized I wasn't de-rating the heat output so I think that's where I was going wrong. I guess what I'm trying to find out is the following,
"If I was a unit of fuel going into the generator how many units of energy would I make, how much heat would I make and how much waste would I make."
I apologize for my inexperience, I am very unfamiliar with CHP machines.
A kWh is an energy unit, not power.
kJ/kWh is the normal way to express fuel consumption for an engine fuelled by gas. Convert to kJ/kWs (divide by 3600), take the reciprocal, and that is your efficiency.
For overall efficiency, you also need to consider the amount of heat you are recovering through your CHP system.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
