Min and max in order of operations
  • Thread starter Thread starter eyec
    Max Operations
The discussion centers on the order of operations for the min and max functions, specifically whether min or max should be applied first in expressions like min_{i \in I}max_{j \in J}. The consensus is that the standard convention is to evaluate from right to left, meaning max is calculated before min. Participants clarify that min and max must act on a collection of objects, leading to the interpretation min(max(set of elements)). An example illustrates that taking the min of columns yields different results than taking the max of rows, reinforcing the importance of the order. Overall, the right-to-left evaluation is affirmed as the correct approach.
eyec
hi,
i was unfortunately unable to find any information about the order of operations in which to apply min and max. (or is it just common knowledge for everyone except me?) consider
min_{i \in I}max_{j \in J} (set of elements with indices i \in I and j \in J)
(actually, this is from http://www.cs.ubc.ca/~kevinlb/teaching/cs532a%20-%202003-4/folk.pdf p.1 which refers to in http://dx.doi.org/10.1016%2F0022-0531(79)90002-4 (which is, however, not free), p.4.) is the minimum or the maximum function applied first? the context in the mentioned papers seems to imply that the first one (min) has precedence. This, however, does not seem intuitive to me because then we have a notation "operation1 operation2 arguments" and do operation2(operation1(arguments)).
thanks ...
Mathematics news on Phys.org
Hey eyec and welcome to the forums.
The usual convention for this kind of thing is to evaluate things from right to left, but if in doubt you should consult the author for clarification.
So with the usual convention, max is evaluated first and then min.
thanks chiro,
so I'm at least certain that I'm not completely wrong about how to deal with max, min ... etc.
maybe i'll ask the author ... in case I find out something, I'll post that again.
min and max must act on a collection of objects. So there is only one way to iterpret your expression that makes any sense, and that is
min ( max ( set of elements ) )
You normally write it as
min max ( set of elements )
because the outer ( )s don't add any more information about what it means.
You usally need ()'s around the "set of elements", because the notation for the set is often fairly long and complicated and it's not obvious where it ends.
This is no different from writing say
log sin (x/2)
You wouldn't normally write
log (sin (x/2))
because that's the only thing the expression could mean. But of course
log sin (x/2)
and
sin log (x/2)
mean two different things.
thanks AlephZero,
you are certainly right (& so is chiro).
probably the author also meant it like that. if someone wants to examine it, on sciencedirect the paper costs a lot of money but on the author's website you can download it for free. (I just realized that now.) http://arielrubinstein.tau.ac.il/papers/03.pdf
the equation in question is on page 4, first line of section 3.
The order is important. Consider
1 2 3
4 2 0
3 2 1
If I take min in each col I get 1, 2, 0, the max of which is 2.
If I take the max of of each row, I get 3, 4, 3, the min of which is 3.
There's some theorem that says min of max >= max of min.
As others have noted, right-to-left is the only valid interpretation.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
