Planck Philosophy...
JesseM said:
Is this equation something you derived yourself based on your own ideas, or did you get it from a textbook or something written by a professional physicist?
[tex]\boxed{\rho_u = \frac{M_u}{2} \sqrt{ \frac{c^3}{\hbar G}}}[/tex]
The solution for this 'non-rotating' classical schwarzschild singularity density for a one dimensional 'point-like' object was derived by me based on research on these physical models.
Note that the Schwarzschild solution is only a solution for Schwarzschild BHs with zero angular momentum , this is a highly improbable state.
Neutron star spin increases with increased density, therefore an object generating in the core of a neutron star or supernova without spin is...impossible. Only BHs with angular momentum can exist in the Universe, a rotating Kerr BH.
JesseM said:
Would you agree that according to classical GR alone, the singularity has infinite density?
The Classical General Relativity model is based upon four total dimensional space-time [tex]n_t = 3 + 1 = 4[/tex] (3 space + 1 time). Solutions for models for that contain dimensions of less than four are not valid solutions in the Universe.
The classical solution stated for 1 dimension is actually 2 dimensions [tex]n_t = 1 + 1 = 2[/tex] (1 space + 1 time), because solutions with with a total dimensional range of less than 4 [tex]n_t < 4[/tex] cannot exist in the Universe, all solutions for total dimensional ranges between 0 and 3 are not real valid solutions because they cannot exist in a four total dimensional General Relativity Universe.
Classical General Relativity models based upon 0 to less than 2 total dimensions are typical of producing solutions with 'infinities', and is only a division by zero in an 'undefined' model.
This solution is based upon 2 dimensional space, the singularity described 'exists' in only 2 space dimensions (and 1 time) [tex]n_t = 2 + 1 = 2[/tex] (2 space + 1 time). [tex]n_t = n_s + n_t[/tex].
Classical Schwarzschild Singularity Dimension Number:
[tex]n_s = 2[/tex] - dimension #
[tex]dV_s = \pi r_p^2[/tex] - volume
[tex]L = 0[/tex] - angular momentum
Solution for 'non-rotating' Classical Schwarzschild Singularity Density for a two dimensional 'point-like' object: (flat disc)
[tex]\rho_s = \frac{dM_s}{dV_s} = \frac{dM_s}{\pi r_p^2} = \frac{M_u c^3}{\pi \hbar G}[/tex]
[tex]\boxed{\rho_u = \frac{M_u c^3}{\pi \hbar G}}[/tex]
[tex]
\begin{picture}(100,100)(0,0)<br />
\put(0,0){\circle{3}}<br />
\put(0,0){\line(1,0){100}}<br />
\put(0,0){\line(0,1){100}}<br />
\put(0,33){\circle{3}}<br />
\put(34,55){\circle{3}}<br />
\put(67,77){\textcolor{red}{\circle{3}}}<br />
\put(67,77){\textcolor{blue}{\circle{6}}}<br />
\put(100,100){\circle{3}}<br />
\put(100,5){{n}}<br />
\put(5,100){{ln p}}<br />
\end{picture}[/tex]
Chronos said:
I would argue the Planck density is the limit in the physical universe.
In a four dimensional space-time physical Universe, the average Planck density is a solution and a physical 'limit' in the Universe.
Based upon the current logarithmic slope in the chart, at what density value does the slope cross the y-intercept?
[/color]
Reference:
https://www.physicsforums.com/showpost.php?p=370142&postcount=24
