Conservation of Momentum: Falling object
The discussion revolves around the conservation of momentum in the context of a ball falling to Earth and the implications of external forces, particularly gravity. Participants explore whether momentum is conserved during the fall and how external influences affect this conservation. The conversation also touches on related scenarios, such as a ball rolling down a ramp.
  • Some participants assert that momentum is only conserved when no external forces act on the system, citing gravity as an external force in the case of a falling ball.
  • Others argue that while the ball's momentum changes due to gravity, the overall momentum of the Earth-ball system remains conserved, as the Earth gains an equal and opposite momentum.
  • One participant questions the scenario by asking how the ball was initially in the air, suggesting that the setup may be unrealistic.
  • Another participant emphasizes that the momentum of a single particle is not conserved when external forces act on it, highlighting that the total momentum of a closed system is what is conserved.
  • In a related scenario, participants discuss the conservation of momentum when a ball rolls down a ramp, concluding that while the ball gains momentum, the total momentum of the Earth-ball system remains conserved.
Participants express differing views on whether momentum is conserved for the falling ball, with some agreeing that external forces prevent conservation for the ball alone, while others maintain that the total system's momentum is conserved. The discussion remains unresolved regarding the specifics of momentum conservation in these scenarios.
Participants have not reached a consensus on the conditions under which momentum is conserved in the discussed scenarios, and there are unresolved assumptions regarding the definitions of the system and external forces.
FZX Student
Does a ball falling to Earth violate conservation of momentum?
Ask yourself:
Under what conditions will the momentum of a system be conserved?
Don't double post.
I'm not quite sure I understand. If momentum of a system is to be conserved then pfinal = pinitial. Meaning m1v1=m2v2. The masses will cancel meaning the velocities have to equal. But they don't. If the ball doesn't hit the ground and is just falling, where is the momentum supposed to be conserved?
Do you agree that momentum is ONLY conserved when NO EXTERNAL FORCES act upon the system?
For your ball, it is certainly influenced by an EXTERNAL force, gravity!
So your conclusion should be that this is not a momentum-conserving situation.
Overall momentum is conserved for a falling object because the Earth gains exactly the same momentum but in the opposite direction.
You've created an unrealistic, asymetric scenario: how did the ball get in the air in the first place?
Consider the ball is in mid-fall, it hasn't hit the ground yet and has not just been released. There are no external forces because gravity is providing the impulse. Is momentum conservered in this case or not?
If you take the ball as your system, then gravity is an external force (as arildno stated) and the ball's momentum is not conserved. This is clearly true, as you know the speed of the ball increases.
Its the total momentum of a closed system that is conserved. Not the momentum of a particle. In your case the particle has a force acting on it and as such the momentum changes. There is no law of physics which states that the momentum of a particle is conserved. The gravitational force changs the momentum of a ball in free-fall. However, as someone explained above, the total momentum of the earth/ball system is conserved. The momentum is therefore
pearth + pball = constant
or
mearthvearth + mballvball = constant
If you start with the ball and the Earth initially at rest then the constant = 0 and then
mearthvearth = -mballvball
Pete
Conservation of Momentum: rolling objects
What about when a ball rolls down a ramp. Is conservation of momentum violated?
No it is not. As the object moves down the ramp it gains momentum. But it should also be noted that there is an equally strong force on the Earth pulling it towards the ball. The acceleration of the Earth caused by the ball's gravity is negligible. Thus one can conclude that the change in momentum of the ball is equal [in magnitude] to the change in momentum of the earth, but in the opposite direction. Therefore the net change of momentum is zero and the law of conservation of momentum holds true.
Amazing that after 2 years, I know what I was thinking and it wasn't leading in the right direction...
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 53 ·
  • · Replies 23 ·
