New Reply
A question on impulsive tensions
Share Thread Thread Tools
Jul9-12, 10:37 PM   #1
Two identical blocks, A and b, each of mass 2kg, are fastened to the ends of a rope 2m long. Block A rests on a smooth table, 1m from the edge. The rope passes over a pulley at the edge of the table and block B is held at the height of the tabletop, as shown. B is is then released.
*For visual purposes: the diagram can be found here:
http://books.google.com.my/books?id=...0to%22&f=false
Page 113 Exercise 5B Question 2
2. Relevant equations
Impulsive tension: mv-mu
g=10ms^-2
3. The attempt at a solution
mgh = 1/2mu^2 -> this is used to find the velocity of block B just before the top becomes taut.
u^2 = 4g
u = √2g
Take upward and rightward directions as negative.
Impulse is denoted as I
For block B: -I = 2v - 2√2g
For block A: -I=-2v
-2v-2v=-2√2g
4v=2√2g
v=√2g/2
Take the v as the initial velocity for both blocks A and B (initial velocity of Block A which is moving towards the edge of the table and initial velocity of Block B moving 1m downwards)
u=√2g/2
s=1m
v=0
t=?
s=0.5(u+v)t
t=0.894
However, the answer given in the book is 0.782s
Please include detailed explanations along with your solution, thanks!! :D
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jul10-12, 06:13 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi jiayingsim123!
(try using the X2 button just above the Reply box )
i'm confused
the string goes taut immediately
the initial speed is zero
call the speed v, and the angle θ, and use conservation of energy and one other equation
Jul11-12, 06:28 AM   #3
Recognitions:
That link shows nothing useful in my current old IE7, but from the wording and OP's approach, I'd infer that block B falls 1m before the rope goes taut.
I can't imagine what angle θ might be?
Jul11-12, 06:43 AM   #4
Recognitions:
Hi NascentOxygen!
i can't see the figure either ,
but I'm assuming it's the standard case of the string starting horizontal and stretched
Jul11-12, 07:01 AM   #5
Recognitions:
Quote by jiayingsim123 View Post
u = √2g
I agree, but warn that you are courting trouble if you don't type this as √(2g)
For block A: -I=-2v
-2v-2v=-2√2g
4v=2√2g
v=√2g/2
Or you could have said the KE of the moving block becomes the KE of the pair.
u=√2g/2
s=1m
v=0
t=?
s=0.5(u+v)t
t=0.894
Can you explain why you say v=0? (As I explained, I can't see the diagram at your link.)
Jul11-12, 07:12 AM   #6
Jul11-12, 07:28 AM   #7
Recognitions:
Quote by tiny-tim View Post
Hi NascentOxygen!
Fair enough. Poster had better describe the setup then.
Ah, thanks azizlwl
Jul15-12, 11:20 AM   #8
Hi everyone, sorry for not replying sooner, I was a tad busy these few days.
The answer to that question is 0.782s, but I can never seem to get that answer.
After further thought, I think v is not 0 as the block doesn't stop after going down by 1m. I'm thinking along the lines of mgh=0.5mv^2 to get the final speed. But I'm really not too sure! Thanks azizlwl for posting the question! :)
Jul16-12, 05:23 AM   #9
Recognitions:
yes, thanks azizlwl!
u^2 = 4g
u = √2g
For block A: -I=-2v
-2v-2v=-2√2g
4v=2√2g
v=√2g/2
looks ok so far …
now use s = ut + 1/2 at2 twice, once for the first metre (a = g), and once for the second metre (a = g/2)
Jul16-12, 09:00 AM   #10
Hi tiny-tim, thanks. But what should be the value of u? And if you were to do it, would you get 0.782? Sorry for my persistent asking of questions but what is the rationale behind doing what you suggested? Thanks in advance! :)
Jul16-12, 09:08 AM   #11
Recognitions:
for the first metre, u = 0
for the second metre, u = (√2)g/2
i've no idea
you tell us!
Jul16-12, 10:53 AM   #12
Hi tiny-tim, I tried doing what you suggested, but I got 0.774 instead of 0.782, which is actually really close.
This is what I did:
Take g=10m/s^2
For the first metre:
s=ut+0.5at^2
1=0.5gt^2
t=sqrt1/5
= 0.447
For the second metro
s=ut+0.5at^2
1= √(2g)/2t + 0.5(g/2)t^2
t=0.327
Total time elapsed=0.774
Sorry tiny-tim, but could you explain why you suggested this? I cannot really see the rationale, I'm sorry! :( Thanks in advance!
Jul16-12, 11:48 AM   #13
pcm
Take g=10m/s^2
i get 0.782 if i take g=9.8 m/s^2.
Jul16-12, 01:40 PM   #14
Recognitions:
Since I feel a little grumpy today , I'm going to complain about how the problem is stated. Although it may seem natural to assume that both masses come to the same speed immediately after each receives the impulse from the rope, that's an assumption that should have been stated in the problem. It's similar to having a 2-body collision problem and just assuming that it's completely inelastic.
It's interesting to rework the problem assuming an elastic (but still very stiff) rope where no mechanical energy is lost in the "collision".
Of course you could have a case anywhere in between the completely inelastic and elastic cases.
(Now I feel a little better )
Jul16-12, 01:54 PM   #15
Recognitions:
hi jiayingsim123!
because for the 1st metre, the mass m is falling on its own, with acceleration g
and for the 2nd metre, the total mass 2m is falling, with external force only mg, so the acceleration is g/2
Quote by TSny View Post
… It's similar to having a 2-body collision problem and just assuming that it's completely inelastic.
no, the energy lost in the collision isn't relevant, conservation of momentum determines the speeds
(though i agree that if the rope is stretchy, that will add slightly to the time taken)
Jul16-12, 02:00 PM   #16
Recognitions:
hi jiayingsim123!
Hi tiny-tim. If no mechanical energy is lost in the collision, what would the speed of each mass be right after the collision?
Jul16-12, 02:10 PM   #17
Recognitions:
it is lost
i'm only saying it isn't relevant
the motion is determined by conservation of momentum and by the constraint v1 = v2 (ie the collision is completely inelastic)
New Reply
Tags
impulse, impulsive tension, mechanics, physics
Thread Tools
Similar Threads for: A question on impulsive tensions
Thread Forum Replies
Impulsive force question Introductory Physics Homework 1
Urgent Question - Tensions and acceleration Introductory Physics Homework 35
Another Simple Rope Tensions Question.. Introductory Physics Homework 3
Lagrange’s equations for impulsive forces (Question) Advanced Physics Homework 0
Impulsive Tensions Introductory Physics Homework 1
