Java Can I assign probabilities to events in Java?
To assign a probability to an event in Java, a random number generator can be utilized to simulate randomness. By generating a uniform random number between 0 and 1, you can create an if/else statement to determine whether a specific arithmetic operation should occur based on a defined probability. For example, if the generated number is less than 0.8, the operation will execute, reflecting an 80% chance of occurrence. This approach allows for the implementation of probabilistic behavior in code without needing a complex algorithm.
stonecoldgen
Hello.
So I'm wondering if there is a way to assign a probability to a certain event in the code.
Let's say that I want a certain arithmetic operation to have an 80% chance of happening (and make an if/else if statement based on that, or something similar...)
Is there something in the java language that can help me? or should I just create an algorithm to do it?
Thanks a lot.
Technology news on Phys.org
Hey stonecoldgen.
Although computers are engineered to always perform an instruction and get the right output pretty much 100% of the time, what you can do is use a good random number generator to simulate the random behaviour: it won't be purely random but it should be good enough.
So what you can actually do is have two options: the output of not doing something and the output of your arithmetic operation occurring. So in pseudo-code:
Code:
randomnumber = generate_uniform_random_number_between_0_and_1();
if (randomnnumber < 0.8)
   do_arithmetic_operation();
else
   dont_do_arithmetic_operation_or_something_else();
end if
You can implement other stuff the same kind of way.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
