Calculating Stellar radius from bolometric flux
In summary: F_{\lambda}(T) = \frac{2h\pi c^{2}}{\lambda^{5}} \frac{1}{exp(hc/\lambda KT)-1} Wm^{2}m^{-1} where F_{\lambda}(T) = \frac{\Delta E}{\Delta A \Delta \lambda \Delta t}The measured spectrum of the star peaks at a wavelength of 650 nm. Assuming thestar radiates as a black body, T = \frac{2.898 \times 10^{-3} mK}{6.5\times 10^{-9}m}Bolometric surface flux
lquinnl
The monochromatic flux emitted from unit surface area of a black body is given by
[tex] F_{\lambda}(T) = \frac{2h\pi c^{2}}{\lambda^{5}} \frac{1}{exp(hc/\lambda KT)-1} Wm^{-2}m^{-1} [/tex]
If the distance to star X is 620 parsecs, calculate:
(a) the radius of star X, in Solar radii; [3]
(b) the bolometric luminosity of star X, in units of Solar luminosity. [1]
OK so I know if we integrate the given equation between 0 and infintiy we get the bolometric flux for F(T). When we perform this integration we end up with the stefan Boltzmann equation:
[tex]F(T) = \sigma T^{4} Wm^{-2}[/tex]
this enables me to calulate the bolometric surface flux, great.
Now i want the radius of star X. I am aware that
[tex]F^{bol} = (\frac{R}{d})^{2}\sigma T^{4}[/tex]
where R is the stellar radius and d the distance to the star.
My problem comes here. I can't calculate the flux from the stefan Boltzmann equation and use it in this last equation because I will always have the distance to the star equal to the radius, which cannot be correct.
Any help would be greatly appreciated
Everything you've said is correct except the final conclusion. The flux received here on Earth is hugely less than the flux emitted at the surface of the star, because the factor R/d is much much less than 1. Why do you conclude that it is equal to 1? Do you know how to calculate the bolometric flux, given a brightness measure, such as magnitude?
I know the apparent magnitude is related to flux by the relationship
[tex]m=-2.5log_{10}(F)+ constant[/tex]
am i to somehow use this to calculate the bolometric flux at the given distance then use this flux on the left hand side of
Although i do not know the magnitude of the star, apparent or absolute.
You must be given some additional information about star X, no?
A star X is observed in the V-band filter (central wavelength 550 nm, bandwidth
88 nm) using a telescope with a diameter of 40cm. The telescope and camera detect
50% of the incident photons and, during a 10 sec exposure, 5500 photons are detected.
I have calculated the monochromatic flux of the star.
So from here should i calculate the magnitude?
No need to calculate the magnitude. You should be able to calculate the emitted flux from the equation you wrote in the first post. Then you should be able to calculate the flux here on Earth from the information you are given. What is their ratio?
Unless I am mistaken or you have been given additional information, you will need to assume some temperature for the star, since you are only given the flux at a single wavelength.
OK so I have:
Monochromatic flux detected from Earth:
[tex]F_{\lambda} = \frac{\Delta E}{\Delta A \Delta \lambda \Delta t}[/tex]
[tex]T = \frac{2.898 \times 10^{-3} mK}{6.5\times 10^{-9}m}[/tex]
Bolometric surface flux:
[tex]F^{bol} (T)= \sigma T^{4}[/tex]But surely I cannot compare Bolometric surface flux to Monochromatic flux detected on Earth because they are over different wavelength ranges.
I would guess the wavelength given is at the peak of the energy spectrum.
edit: I see it is not.
lquinnl said:
OK so I have:
OK, looks good.
right idea, but is 650nm = 6.5*10^-9 ?
Why would you want to? You have calculated Flambda here on Earth. Your first post gave the formula for Flambda at the star's surface. Compare these two.
Ooops so 650nm should be 6.5 x10^-7 m.
So compare
[tex]F_{\lambda}(T) = \frac{2h\pi c^{2}}{\lambda^{5}} \frac{1}{exp(hc/\lambda KT)-1} Wm^{2}m^{-1}[/tex]
with
[tex]F_{\lambda}(T) = \frac{\Delta E}{\Delta A \Delta \lambda \Delta t}[/tex]
then use this ratio, call it Z ,to calculate the Fbolometric at the distance of 620 parsecs.
we know that F bol at star surface is:
[tex]F^{bol}(at surface) = \sigma T^{4}[/tex]
and because
[tex]F^{bol}(atdistance) = (\frac{R}{d})^{2} \sigma T^{4}[/tex]
we have:
[tex]F^{bol}(at surface) \times Z = (\frac{R}{d})^{2} \sigma T^{4}[/tex]
then rearrange for R
Sound good?
No! Forget the total, integrated flux, what you're calling Fbol, because you don't know this value at the Earth. Just compare the flux in the measured wavelength band to the calculated flux in that same band from your formula for Flambda. This ratio will be (R/d)^2
So the ratio of this
to this:
[tex]F_\lambda = \frac{\Delta E}{\Delta A \Delta t \Delta \lambda}[/tex]
is
[tex] (\frac{R}{d})^{2}[/tex]
Right. Do you see why? The first is the flux at the star's surface. The second is the measured flux at the Earth. Since the flux drops of as (1/r)^2, the ratio is equal to the ratio of the radii squared.
Yeah that makes sense now!
Thank you very much for sticking with me and helping out with this problem. I'm trying to revise for an exam and I was hittting a brick wall with that!
Thanks again
1. How is bolometric flux related to stellar radius?
Bolometric flux is the total amount of energy emitted by a star in all wavelengths of light. It is directly proportional to the surface area of the star, which is in turn related to its radius. The larger the radius, the greater the surface area and therefore the higher the bolometric flux.
2. What is the formula for calculating stellar radius from bolometric flux?
The formula is: Radius = sqrt(L / (4πσT4)), where L is the bolometric flux, σ is the Stefan-Boltzmann constant, and T is the effective temperature of the star.
3. Can stellar radius be calculated using only bolometric flux?
No, calculating stellar radius from bolometric flux also requires knowing the effective temperature of the star. This can be determined through other methods such as spectroscopy or by using the star's spectral type.
4. Are there any limitations to using bolometric flux to calculate stellar radius?
Yes, there are several limitations to using bolometric flux. Firstly, it assumes that the star is a perfect blackbody, which may not be the case for all stars. Secondly, it does not take into account any potential absorption or scattering of light by the star's atmosphere. Lastly, it may not be accurate for stars with very high or very low temperatures.
5. How accurate is the calculated stellar radius from bolometric flux?
The accuracy of the calculated stellar radius depends on the accuracy of the measured bolometric flux and effective temperature. In general, it is a good estimate but may not be precise for all stars due to the limitations mentioned earlier.
  • Astronomy and Astrophysics
