| New Reply |
help finding potential energy of submerged buoyant object |
Share Thread | Thread Tools |
| Aug11-12, 04:12 PM | #1 |
object is the shape of a ball 300 feet in diameter. (~100m)
object weighs 100,000 lbs (~50,000 kg) object is at a depth of 1000 feet (~300m) I just need a rough estimate - you can use meters or feet or whatever, i don't care. salt or fresh water is fine but if there is a choice salt. do I need more information about the object? can it be deduced how buoyant it is by its diameter and weight? I don't have a specific buoyancy in mind so if the diameter is not wide enough to allow the object to be buoyant then you can increase the diameter. Again, I just need a rough estimate, so if you just assume a certain level of buoyancy that is fine. I would appreciate any help on this... I am researching the answer but have no background in physics so I'm going too slow for my liking. |
| Aug11-12, 11:16 PM | #2 |
Recognitions:
The potential energy will be equal to the amount of work required to get object to that position. If you take surface as reference point, that is, count object on surface as zero potential, then the potential will be net force (buoyant force - weight) times depth. Should be easy enough for you to do the math.
| Aug11-12, 11:34 PM | #3 |
The buoyant force acting on a object is completely determined by its size, so, no, you don't need more information. If you want to know whether this buoyant force will be enough to support its weight, you need to know its mass too. Thus, whether an object sinks or floats is determined completely by its density. So, you can't make a sinking object float just by making it larger, unless you're adding a lower density material.
As for your question: the relevant physics law is Archimedes' principle, which says that the upward buoyant force on an object is equal the weight of the displaced water. The density of salt water is around [itex]1025 kg/m^3[/itex]. The pressure at 1000ft probably isn't enough to significantly increase this. So, the buoyant force is: [itex]F_B = \frac{4}{3}\pi(100m/2)^3 \cdot 1025kg/m^3 = 5.4\times10^8N[/itex] where I've used the water's density and the formula for the volume of a sphere (the volume of water displaced). [edit: this is incorrect, I calculated the mass of the water instead of its weight. I missed a factor of [itex]9.8m/s^2[/itex]. The rest of calculation proceeds the same way, but DrZoidberg has already done it, so I won't recalculate everything.] Meanwhile, the force of gravity is: [itex]F_g = -mg = -50 000 \cdot 9.8m/s^2 \approx -5\times10^5N[/itex] (Note the minus sign since the weight and buoyant force are in opposite directions.) This object is very buoyant, the magnitude of the weight is much less than the buoyant force. Your object's density is only about [itex]240 kg/m^3[/itex], much less than salt water. So, the total force on the object is the sum, which is still about [itex]5.4\times10^8 N[/itex]. This force is approximately constant all the way down (assuming, in addition to the constancy of the water's density that the change in the acceleration due to gravity on the way down is negligible). This means the potential energy has the simple form: [itex]U = -F\Delta x[/itex] where [itex]\Delta x[/itex] is the change in height as the object descends, which is [itex]-300m[/itex] relative to the surface. Therefore: [itex]U = 5.4\times10^8 N \cdot 300m \approx 1.6\times10^{11} J[/itex] which is positive, as you should expect for a buoyant object. That's 160 gigajoules of potential energy, if you define the zero of potential energy to be at sea level. |
| Aug12-12, 05:20 AM | #4 |
First you need the volume of your object.
4/3*pi*(50m)^3 = 523,599 m^3 50,000kg / 523,599 m^3 = 0.095 kg/m^3 = 0.095 g/l That's approximately the density of hydrogen. Are you sure all your numbers are right. Is the object really 100m large? Force of boyancy is (volume of object * density of water - weight of object) * g (523,599 m^3 * 1000kg/m^3 - 50,000kg) * 9.81 N/kg = 5.136 * 10^9 N Energy = force * distance 5.136 * 10^9 N * 300m = 1.54 * 10^12 J However since the object is relatively large comparted to the depth, that result is not very accurate. |
| Aug12-12, 10:00 AM | #5 |
Thank you very much for all your answers, they were very helpful, especially lastonestanding. I will make adjustments since obviously I don't think a density equivalent to hydrogen is realistic (is that really possible).
I hate to ask another question but how do I calculate the amount of time it takes to travel those 300M upwards? Thanks in advance |
| Aug12-12, 11:05 AM | #6 |
DrZoidberg's numbers are correct, I made an error when calculating [itex]F_B[/itex]. I calculated the mass of the displaced water, not its weight. So, use his/her results.
Also, as DrZoidberg pointed out, the result is less accurate due to the ball's size being comparable to the depth. For a rough answer for the time, though, determine the object's acceleration (net force divided by its mass) and plug it and the depth (and a starting velocity of zero) into the appropriate kinematic equation (http://www.physicsclassroom.com/class/1dkin/u1l6a.cfm) to find the time of ascent. |
| Aug12-12, 11:43 AM | #7 |
ok, thanks for pointing that out and thank you to drzoiberg. i changed the diameter to 10meters which i think is more realistic given depth and density considerations.
| New Reply |
| Thread Tools | |
Similar Threads for: help finding potential energy of submerged buoyant object
| Upthrust in a fully submerged object | General Physics | 3 | ||
| Motion of an object submerged in water. | Mechanical Engineering | 5 | ||
| Force on an object submerged | Introductory Physics Homework | 4 | ||
| submerged object/density | Introductory Physics Homework | 1 | ||
| volume of a object by being submerged | Introductory Physics Homework | 3 | ||
