Question about theorem 2.2.1 in Wald's General Relativity
CJ2116
Hi everyone, first of all I have been a lurker here for years and have benefited greatly from many of the discussions in the math and physics sections. Thanks, I have received a lot of helpful information from these forums!
I have been working through Wald's General Relativity book and I am having trouble following the reasoning behind one part of a theorem. From page 15, the theorem and part of the proof is (For those who don't have the book):
Let M be an n-dimensional manifold. Let p \in M and let V_p denote the tangent space at p. Then dim V_p=n
Proof We shall show that dim V_p=n by constructing a basis of V_p, i.e. by finding n linearly independent tangent vectors that span V_p. Let \psi : O \rightarrow U\subset R^n be a chart with p\in O. If f\in \mathfrak{F}, then by definition f\circ \psi^{-1}:U\rightarrow R is C^{\infty}. For \mu=1,...,n define X_{\mu}:\mathfrak{F}\rightarrow R by
$$X_{\mu}(f)=\frac{\partial}{\partial x^{\mu}}(f\circ \psi^{-1})\bigg|_{\psi (p)}$$
$$\vdots$$
I can't seem to figure out how the term \frac{\partial}{\partial x^{\mu}}(f\circ \psi^{-1})\bigg|_{\psi (p)} is a mapping from \mathfrak{F}\rightarrow R. f\circ \psi^{-1} was defined to be a mapping from U\rightarrow R. In other words, I don't see why these last two terms should be equal. I think I am missing something obvious here. Is there maybe some sort of chain rule argument?
Thanks, any pointer in the right direction would be greatly appreciated!
You have f o \ \psi^{-1}(\psi(p)) = f(p).
Wow, that was more embarrassingly obvious than I thought!:blushing:
Thanks for the reply!
Don't worry. It is easy to drown in all those formalities ;)
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
