Physical Explanation of Faraday's Law
The discussion revolves around the physical interpretation of Faraday's Law, particularly in the context of changing magnetic fields and induced electric currents. Participants explore various conceptual and mathematical aspects of the law, including its implications for electromagnetic fields and the nature of electric and magnetic interactions.
  • One participant expresses confusion about how a changing magnetic field can induce an electric current in a wire that is not in direct contact with the field, suggesting a need for a physical mechanism such as photons for interaction.
  • Another participant challenges the initial example of a magnetic field, stating it violates the condition \nabla \cdot \vec B=0, and proposes that a changing magnetic field induces an electric field that curls around the change.
  • A different perspective is offered, explaining that an induced electromotive force (emf) can be understood through the analogy of a conducting ring moving through a static magnetic field, where charges experience a force due to their velocity in the field.
  • One participant argues that the electric field exists independently of charges, as evidenced by electromagnetic waves, and suggests that Lorentz transformations can provide a physical explanation for this phenomenon.
  • Another participant clarifies that the induced current is greatest when the magnetic field is changing most rapidly, not when it is absent, and provides an analogy involving a bar magnet and a coil of wire to illustrate this point.
  • A participant raises a concern about the implications of Green's theorem, questioning how a circular loop can be influenced by a magnetic field that is only defined within a smaller radius, seeking a physical explanation for this perceived violation of locality.
  • In response, another participant asserts that it is not a violation of locality, explaining that magnetic field lines must be closed and that the net flux through a loop depends on the configuration of the field lines relative to the loop.
Participants express differing views on the interpretation of Faraday's Law and the nature of electric and magnetic fields. There is no consensus on the physical mechanisms involved or the implications of certain mathematical conditions, indicating ongoing debate and exploration of the topic.
Participants highlight limitations in their understanding of the relationship between magnetic fields and induced currents, particularly regarding the role of locality and the conditions under which Faraday's Law applies. The discussion reflects a variety of interpretations and assumptions that remain unresolved.
Lyuokdea
So we were going through Faraday's Law today in class:
[tex]\int\vec{E}\cdot d\vec{l} = -\frac{d}{dt}\int\vec{B}\cdot d\vec{A}[/tex]
Mathematically I'm fine with it, however, is there any good physical way to explain it, it seems very odd that if you had a field such as:
[tex]\vec{B} = B_0cos(\omega t)\hat{z}[/tex]
and that field was defined only in some circle of radius R that if you had a ring around R that the induced electrical current would be the greatest when the magnetic field doesn't exist, how does one object feel another objects change through time? I understand this in terms of a force for things like velocity, but that is only because the objects are in physical contact, however, the magnetic field isn't touching the right at all.
I would assume that there are photons moving between the field and the wire, or virtual photons or something would be necessary for the wire to "see" the magnetic field at all, however when those photons don't exist, how does the magnet react to them?
~Lyuokdea
Your example is not possible, since it would violate [itex]\nabla \cdot \vec B=0[/itex].
Anyway, I don't really understand where the problem is in your understanding. The idea is that a change in [itex]\vec B[/itex] at a certain point induces an entire electric field which curls around -d/dt B. Maybe the differential form of Faraday's law is more intuitive (apply Stokes):
[tex]\nabla \times \vec E = -\frac{\partial \vec B}{\partial t}[/tex]
As to why this is true I can't give a complete answer. Maybe you'll find it sufficient that, given an electric field and relativity, this must give rise to effects like Faraday's law.
There are two ways to look at faradays law.
If you have a conducting ring and a changing B field (your example) then an "emf" appears in the ring. This can be physically explained: imagine that instead of B changing, it is the the ring which is moving in a static B field (this situation appears in Faraday's law problems anyway).
Now, those are charges moving through a B field with a velocity, so they feel a force q(vxB). Now, here we go: q(vxB) is the emf! If you do the right hand rule, q(vxB) points in the direction of the emf. If you set up a calculation, you will get the same result this way as using Faraday's law.
But Faraday's law is deeper than that, because there doesn't have to be a ring there or any charges! In otherwords, the electric field is a real entity because it shows up even without any charges (we know it is there because that's why we have em waves). This is also easy to explain physically, all you need to know are the lorentz transformations.
Not really.. [tex]\frac{\partial}{\partial z} [B_0 \cos(\omega t)] = 0[/tex]
The z component has no dependence on z, so I see no problem there.
Lyuokdea said:
... and that field was defined only in some circle of radius R that if you had a ring around R that the induced electrical current would be the greatest when the magnetic field doesn't exist, how does one object feel another objects change through time?
So you don't want to get caught in thinking the current is greatest when the field doesn't exist, but that it's greatest when the field is changing most rapidly... ie if your B field was like [tex]B = B_0 cos(\omega t) + B_1[/tex], [tex]B_1[/tex] could be really huge, and then the current would be greatest at some middle value of the B field.. crosson's explanation is maybe the best way to think about it.. you could have a coil of wire and push a bar magnet in and out of the coil, or you could reverse the situtation and have a bar magnet fixed and push the coil back and forth over the magnet. Both situations are equivalent, as long as the velocities are the same
I think the part that is messing with me the most is the Green's theorem part, that since it is a circular loop around a path, then everything inside the circular loop matters, and not the things that are actually where the loop is.
So that if you had a circular loop of Radius 2R and the magnetic field was only defined in the area with radius R, the circular loop would still be affected by the magnetic field, although there is no magnetic field in any place where the loop exists. Is there any good physical explanation for this violation of locality?
~Lyuokdea
I don't think it's a violation of locality. Remember, B field lines have to be closed. If you move a magnet in and out of a loop of wire, if all the field lines are within the enclosed area, then there is no net flux because there is the same amount of B field going up and going down. Otherwise, the B field lines have to cross over the wire loop as you move the magnet.
