| New Reply |
Searching for a nice explanation: Plane Mirror |
Share Thread | Thread Tools |
| Oct29-12, 07:09 AM | #18 |
| Oct29-12, 08:26 AM | #19 |
Mentor
To see more clearly where the usual left-right reversal in a mirror image comes from, first note that in my picture, the letters are written on the side of the plastic sheet that faces me. Now imagine replacing the clear plastic with cardboard. We no longer see the letters in the mirror because they're on the "wrong" side of the sheet, facing away from the mirror.
To make the letters visible in the mirror, we need to flip the sheet around. If we flip the sheet horizontally (around a vertical axis), we see the usual "mirror-reversed" image. What happens if instead, we flip the sheet vertically (around a horizontal axis)?
| Oct29-12, 08:33 AM | #20 |
| Oct29-12, 09:05 AM | #21 |
Anyway, everything has been explained several times now.
| Oct30-12, 10:16 PM | #22 |
New here :-) a mirror reflects light. It does not reflect psychology .. up, down, right, left has no definition outside of human behavior. I see that as the biggest problem in physics. Go find the right side of the earth .. the bottom of a star. Maybe the question is, "where does human behavior stop and physics begin?" In psych class one night, professor asked us to "calculate the statistical probability of a bird landing on a branch during a heavy storm." Long pause .... it's 100% ! The bird behaves. He doesn't care about physics or math. And we're pretty good with mirrors.
| Nov2-12, 03:09 PM | #23 |
Trying to summarize:
The operation that is implemented by the mirror on the system of light rays which emerge from an object may be called mirroring and has to do with a front-back inversion. As this operation is mechanically unpractical, our brains tend to interpret it as a rotation around a vertical axis followed by an inversion left-right. Mathematically we may see it from the equivalence between two procedures: 1) (x , y , z) -> (x , -y , z) reflection in the xz-plane. 2) (x , y , z) -> (-x , -y , z) rot 180 around z-axis followed by (-x , -y , z) -> (x , -y , z) reflection in the yz-plane (exchange of left and right) Best wishes, DaTario |
| Nov18-12, 07:22 AM | #24 |
| Nov19-12, 07:56 AM | #25 |
What the mirror does is the same as writing in wet ink... . Top .Left Right . Bottom on a piece of paper, say stuck on a wall in front of you, and then getting a friend to put another piece of paper on top of the still wet writing and then they move that paper away from the wall, without that person turning the paper in any way. Now if you turn your head from looking at the paper on the wall, to the one your friend is holding (the mirror image), you will see Left and Right switched, but Top still at the top and Bottom still at the bottom. However, you could also look at the piece of paper your friend is holding by bending down and looking through your legs. If you were to do this, then you would see Bottom at the top and Top at the bottom, with Left still on the left, and Right still on the right. As we normally just turn our heads when looking at a mirror image (rather than look through our legs), we see left and right switched, and top and bottom staying as they are. |
| New Reply |
| Thread Tools | |
Similar Threads for: Searching for a nice explanation: Plane Mirror
| Images in plane mirror. | General Physics | 2 | ||
| Reflection from a plane mirror | Introductory Physics Homework | 7 | ||
| Plane Mirror problem... | Introductory Physics Homework | 1 | ||
| Need help on Plane Mirror | Introductory Physics Homework | 2 | ||
| searching for a string explanation | General Astronomy | 108 | ||
