Fermi level makes doped and undoped different?
  • Thread starter Thread starter Outrageous
    Fermi Fermi level
The Fermi level in semiconductors indicates the energy level where there is a 50% probability of finding electrons at any temperature. In undoped semiconductors, the Fermi level is positioned between the conduction and valence bands, while in n-type doped semiconductors, it shifts closer to the conduction band, enhancing conductivity. This shift is due to the introduction of loosely bonded electrons from pentavalent atoms, which increases the density of free electrons available for conduction. The Fermi level's position directly influences the probability of electron occupancy in energy states, affecting overall conductivity. Understanding these concepts clarifies the differences in conductivity between doped and undoped semiconductors.
Outrageous
The intrinsic semiconductor
Fermi level is the maximum energy level an electron can be in at 0K.
Or Fermi level is a level where there is a probability of 50% to find electrons at any temperature.
Conduction band is a range of energy where electrons freed from bonding stay.
Valence band is a range of energy where electrons in a bonding between atoms stay.
In undoped semiconductor, the Fermi level is in between the energy gap, which is lower than conduction band but higher than the valence band.
We studied that when an electron absorbs thermal energy, it will be excited to the conduction band by crossing the band gap which is where the Fermi level at.(Why do we need to define Fermi level? It is used for?)
Is that because...
In extrinsic semiconductor, the Fermi level of n-type shift to the conduction band, while that of p-type shift to the valence band. ( Is that what making the doped semiconductor having higher conductivity? So that is also the reason affect the density of hole and electron? Then how can the conductivity of doped semiconductor increase just by shifting the Fermi level? Let’s say n-type, the Fermi level shift towards the conduction band but the conduction band is still stay at the same energy level, then that means electrons in valence band still have to absorb same amount of energy as in undoped semiconductor in order to excite to the conduction band. So the only thing that makes doped and undoped different is the Fermi level and the density of eletron. But how is that going to affect? Apart from that, my book says the n-type has higher conductivity because there are electrons from pentavalent atoms which are loosely bonded, so how should I relate the Fermi level of n-type with the loosely bonded electrons? )
Please help to check whether my concept is correct and answer me. Thank you.
You're partially confused. The Fermi level is the energy of a hypothetical state with probability of being occupied equal 50%.
To realize this, you need to consider the Fermi distribution function f(E) which tells you how probable it is that a state is occupied. You will realize that under equilibrium conditions, if a state is located at an energy larger than E_F + 3*kT, it is highly unprobably that it is occupied. Conversely, if it is located at E_F - 3*kT, it is extremely probably that it will be occupied.
The Fermi level shifts *because* of the doping, not the other way around.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
