Can I hook a 50 Ohm Variable Attenuator To This Circuit?
The discussion centers on the need to attenuate a strong microphone signal to prevent overload in a lock-in amplifier. The microphone output has an impedance of 30 kOhms, while the proposed solution involves using a 50 Ohm variable attenuator. It is suggested that terminating the microphone output in 50 Ohms could provide significant attenuation, but this may be excessive. Participants recommend creating a custom attenuator matched to the microphone's output impedance for better results. Additional information about the setup, including a block diagram, is requested for more tailored advice.
Bigredbloke
The is the Output circuit of a microphone I'm using to look at photoacoustic signal, is just an Op-Amp, connected to a high pass filter which is using a 30 Kohm resistor. Sadly, the signal the microphone gives is too strong for the lock-in I'm using to read the signal, and overloads it. I want to buy an attenuator in order to lower the signal without disturbing the waveform. When I measured the output resistance of my microphone it was 30 kOhms, which matched the circuit diagram, so I know that is correct.
My question is can I buy an 50 Ohm Attenuator and hook it up to the output of the mic, will it still properly attenuate the signal? If not do you have any other possible solutions? I am trying to attenuate the signal by at least 10 dBV. Thanks for the help!
You can just terminate the output of the microphone in 50 Ohms and parallel tap that into the input of your lock-in amplifier. The 50 Ohm termination of the 30 kOhm source should give about 55 dBV of attenuation. Is that too much? If so, you could just make your own attenuator that is matched to the 30 kOhm output impedance and the input impedance of your lock-in amplifier. It sounds like your signals are all in the audio range, so making your own resistive attenuator should be fairly straightforward.
Likes anorlunda
Welcome to PF.
I think there are better ways of attenuating 10k impedance signals than using a commercial 50 ohm attenuator. You should be able to make a suitable attenuator from a couple of resistors.
We need to know more about the setup you are using before we can advise you of the easy solution.
A block diagram of your system would help us understand your application and requirements.
Can you please post some links to the circuits you are using.
You can also drag and drop files onto your next post.
Likes tech99 and anorlunda
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
