A thin uniform bar, hanging, is hit by a ball. Find the angular velocity
The problem involves a thin, uniform metal bar that is hanging vertically and is struck by a clay ball. The scenario is set in the context of angular momentum conservation to find the angular velocity of the combined system after the collision.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conservation of angular momentum and the correct application of formulas related to the moment of inertia. There is a question regarding the accuracy of the formula used for angular momentum, with some participants suggesting a reconsideration of the calculations.
The discussion has seen attempts to calculate the angular velocity, with one participant initially arriving at an incorrect value and later correcting it. There is acknowledgment of a mistake in the formula used, leading to a revised answer. However, the correctness of the final value is not confirmed by others.
Participants are working under the constraints of homework rules, focusing on understanding the principles of angular momentum without providing complete solutions.
Phys121VIU
A thin, uniform metal bar, 3m long and weighing 75N, is hanging veritcally from the ceiling by a frictionless pivot. Suddenly it is struck 1.3m below the ceiling by a small 2 kg clay ball, initially traveling horizontally at 14m/s. The ball sticks to the bar
Find the angular velocity of the ball+bar just after the collision.
Angular momentum is conserved so my understanding is that
Angular momentum of the ball = angular momentum of the bar and bar
Lball = (Ibar + Iball2
(2kg)(14m/s)(1.3m) = [(1/3)(75N/9.8m/s2)(3m)2 + (2kg)(1.3m)22
so i worked it out and got ω = 1.18 rad/s
but that's not correct...I can't think of any other way to approach it
Are you sure that the last formula is correct?
ehild
Wow..its definitely not squared..thanks:P
Found the answer..1.38rad/s!
Well done !:smile:
  • · Replies 62 ·
14K
  • · Replies 18 ·
