Gyroscope Precession Explained: Simple Explanation
Gyroscopic precession occurs when a torque is applied to a gyroscope, causing it to rotate in a direction perpendicular to the applied force. This reaction is 90° out of phase with the torque, meaning the gyroscope's movement responds later than the input. In practical applications, such as helicopters, adjustments are made to control inputs to account for this delay. The discussion emphasizes a simplified explanation, avoiding complex physics terminology while still conveying the essential mechanics of precession. Understanding these principles is crucial for applications involving gyroscopic systems.
brandontod97
I wanted to know if someone could explain how gyroscopic precession works. Preferably in normal physics terms and in laymens terms. Thanks :)
i checked that link. already, thanks though. assume i don't understand physics.
I'm not sure if this will help, but you could try to imagine a moment in time where the gyro is horizontal with a vertical axis, and that a horizontal plane is used as a reference for the gyro at this moment in time. Assume the gyroscope is precessing along an east - west axis, so that the north side of the gyro is precessing "upwards" and the south side is precessing "downwards". For any point on the gyro, the acceleration component perpendicular to the plane is greatest on the east and west side, and zero on the north and south side (the acceleration component would be a direct reaction to input torque). For any point on the gyro, the velocity component perpendicular to the plane is most negative on the south side, and most positive on the north side, and zero on the east and west side (the velocity component would correspond to the gyro's precession reaction).
The precession reaction is 90° out of phase "behind" the applied torque. Helicopters are affected by this and the cyclic (pitch and roll) output is adjusted 90° "ahead" of the control input to compensate.
This description is ignoring the fact that the overall angular momentum of a gyro is affected by the rate of precession. The actual precession reaction is slightly different than the idealized one.
Ok, but that discussion used less physics than any other discussion of precession that I have seen. It mentions e.g. Newton's second law, but it is not really used mathematically.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
