A (apparently?) non-local quantum field theory
The discussion focuses on deriving the Euler-Lagrange equations for a non-local Lagrangian density of a complex scalar field, defined as \(\mathcal{L} = \partial_{\mu}\psi^* \partial_{\mu}\psi - \lambda \int dy\, f(x,y) \psi^*(y) \psi(y)\). The author successfully applies the functional derivative method, resulting in the equation \(\partial_{\mu}\partial^{\mu}\psi(x) = -\lambda \int dy\, f(y,x) \psi(x)\), indicating a non-constant mass term. The Feynman rules derived from the provided references yield a propagator consistent with a free complex scalar field mass \(m^2 = \lambda \int dx dy f(x,y)\). The author questions the implications of non-locality disappearing in the equations of motion.
  • Understanding of Lagrangian mechanics and Euler-Lagrange equations
  • Familiarity with complex scalar fields in quantum field theory
  • Knowledge of functional derivatives and their applications in field theory
  • Experience with Feynman rules and propagators in quantum mechanics
  • Study the derivation of Euler-Lagrange equations for non-local Lagrangians
  • Explore the implications of non-locality in quantum field theories
  • Investigate the role of coupling constants in scalar field theories
  • Review the methods for calculating transition amplitudes in quantum field theory
Researchers and students in theoretical physics, particularly those focusing on quantum field theory, complex scalar fields, and non-local interactions in particle physics.
rubbergnome
I need to derive the euler-lagrange equations for the following non-local lagrangian density for a complex scalar field ψ
[itex]\mathcal{L} = \partial_{\mu}\psi^* \partial_{\mu}\psi - \lambda \int dy\, f(x,y) \psi^*(y) \psi(y)[/itex]
where λ is the coupling constant, f is a certain real-positive valued function linear in the first argument that satisfies f(x,y)=1/f(y,x) (which also implies f(x,x)=1). The integral is over all spacetime.
Applying the usual euler-lagrange equations shouldn't be correct here. I tried taking the functional derivative of the action S=∫dx L with respect to ψ*and set it equal to zero, and I get
[itex]\partial_{\mu}\partial^{\mu}\psi(x) = -\lambda \int dy\, f(y,x) \psi(x)[/itex]
where indeed we have a non-constant mass term. On the other hand, I used the methods in this paper
http://www.astro.columbia.edu/~lhui/G6047_2012/HowTo.pdf
to derive the feynman rules for the only possible vertex in the theory (this already made me think about a correction to the propagator); I get -iλ∫dxdy f(x,y) which purely depends on f. This result can also be quickly derived with eq. (136) here
http://www2.ph.ed.ac.uk/~egardi/MQFT/mqft_lecture_9_10.pdf
The full propagator is therefore one of a free complex scalar field with mass m²= λ∫dxdy f(x,y). At least this is the result I got, and I'd like to confirm it deriving this mass term in the equations of motion.
I also calculated the leading order correction to the transition amplitude between single-particle states in the canonical formalism, and the result agrees with the above procedure.
The final doubt that arises is this: even if the equations of motions lead to the same result, why would the non-locality in the lagrangian be completely gone, turning into a mass term?
I hope at least part of my post makes sense. Thanks in advance for helping. :)
For some reason I cannot edit the first post anymore. I just wanted to add that x-linearity in f is not required, also because if compromises the positivity. I needed it for other things, but I realized it's not working that way. Deriving the equations of motion shouldn't depend on that anyway.
  • · Replies 49 ·
  • · Replies 30 ·
