| New Reply |
Classical Angular Momentum |
Share Thread | Thread Tools |
| Jan1-13, 03:44 PM | #1 |
[Li,Lj]=εijkLk
how can I prove this expression classically? |
| Jan1-13, 04:29 PM | #2 |
Recognitions:
Classically, L is not an operator, so you cannot define a commutator.
You can show that {Li, Lj}=εijkLk. I don't know if that's what you meant by saying "Classically". If so, just write out Li in terms of qi and pi. If you write the correct expression for it using Levi-Civita symbol and apply definition of Poisson bracket, it should be a trivial matter. |
| Jan2-13, 02:04 PM | #3 |
Yes, exactly. Thank you very much. Using square brackets may be confusing in classical mechanics. I figured out to make this with levi civita symbol. But there is another problem I have now. if I replace the Li with some general vector Vi, it should still be hold
{Vi,Lj}=εijkVk how should I constract a general V vector? |
| New Reply |
| Thread Tools | |
Similar Threads for: Classical Angular Momentum
| angular momentum and conservation of angular momentum problem | Introductory Physics Homework | 0 | ||
| Angular momentum of a particle in Classical Mechanics | Advanced Physics Homework | 12 | ||
| Classical mechanics, angular momentum and velocity not parallel, why? | Introductory Physics Homework | 4 | ||
| Classical Mechanics, angular momentum | Advanced Physics Homework | 1 | ||
| Angular momentum and orbital angular momentum problems | Introductory Physics Homework | 3 | ||
