New Reply
How Can A High-Torque Motor Have Low a low RPM
Share Thread Thread Tools
Jan9-13, 09:01 PM   #1
Torque is the rotational force.
If there is more force, how can the motor be slow?
I'm building a DC motor and read that given a constant amount of coil, creating a very dense coil will increase torque but lower RPMs.
Conversely, making it looser (bigger radius) increases RPM but lowers torque.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jan9-13, 10:07 PM   #2
Recognitions:
Homework Helper Homework Help
The torque gives you acceleration - but it is possible to accelerate to any speed... however slow.
For your motor - it will accelerate to a constant speed due to losses that are proportional to speed. This will be proportional to the amount of mass that has to be spun - and so is the torque.
Jan9-13, 11:41 PM   #3
Recognitions:
The increase in torque at lower rpm is offset by increase in back emf at higher rpm, which decreases the torque at higher rpm.
Jan10-13, 05:23 AM   #4
Mentor
Motors are connected to loads. The load determines the ratio between RPM and torque. If a "high torque" motor is not connected to a load and is just allowed to freewheel, it does not produce any torque.
New Reply
Thread Tools
Similar Threads for: How Can A High-Torque Motor Have Low a low RPM
Thread Forum Replies
Need DC motor having high holding torque Electrical Engineering 2
Motor Torque, Starting Torque, Stall Torque, Load Torque Mechanical Engineering 3
Low RPM, high torque DC motor help Electrical Engineering 7
Low RPM high Torque Motor with enough power to rotate 30 pounds? General Engineering 3
