Why Is Time Compression Represented by x(2t) in Signal Processing?
Time compression in signal processing is represented by x(2t) because it effectively scales the time variable, resulting in a compressed signal. When the time variable is multiplied by a factor greater than one, such as 2, the signal's features occur more rapidly, leading to a compressed appearance. The transformation of the independent variable refers to how the time axis is manipulated, even if it remains labeled as "t." Understanding this concept involves recognizing that the transformed time variable t* is a scaled version of the original time variable. Thus, x(2t) represents the original signal occurring at half the time intervals, illustrating the compression effect.
physio
I have just started a course on signals and systems and am finding the subject confusing.
This question pertains to the transformations of the independent variable which is time in this case. I don't know why it is transformation of the "independent variable" as the time axis is the same as it originally was. The time axis is not "transformed". For example in time reversal of a signal, the signal is simply flipped about the origin and the time axis is unaltered (i.e. 't' stays the same but doesn't become '-t') yet the book says it is a transformation of the independent variable. Am I missing something?
After a reasonable amount of thought can anyone intuitively explain why time compression has a>1 i.e for a signal x(t) why and how x(2t) is the time compressed signal?? I think I will be able to answer the first question if I know why x(2t) is the compressed version of x(t).
Hi physio. Think of it in two steps.
Step 1. Just re-label your time axis as "-t" instead of "t" in the right hand direction. Essentially this is all that the transformation actually involves, however convention requires that the "t" axis to run the other way (so that's why we need step 2).
Step 2. Flip both the "t" axis and the graph together. This step doesn't really change the graph, it merely puts it into the form people expect to see.
The best way to see this is to pick any particular point on your graph, say x_1 = x(t_1) and notice that this same x point on the transformed graph occurs at a transform "t" value of t^* = t_1/2, (as x_1 = x(2(t_1/2)).
Thanks a lot for your reply uart! I understood the time reversal operation with your explanation but I yet have problems understanding the time scaling operation. I understood that the transformed variable t*=t1/2 i.e the transformed time variable is a scaled version (in this case t1 /2) of the original time variable. Hence shouldn't the transformed graph should be x(t*)?? Do we have to consider the graphs together for calculating the new function i.e. x(2t) or x(t/2) i.e. with reference with the original signal? Thanks in advance..!
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
