New Reply
Why is this matrix bad conditioned?
Share Thread Thread Tools
Jan16-13, 06:05 PM   #1
Hi,
From a paper I got a matrix like this which I use to solve the over-determined system [itex]\mathbf{z} = \mathbf{U} \mathbf{a}[/itex]:
[tex]
\mathbf{U} = \left[\begin{matrix}
x(3) & x(3)^2 & x(3)^3 & x(2) & x(2)^2 & x(2)^3 & x(1) & x(1)^2 & x(1)^3\\
x(4) & x(4)^2 & x(4)^3 & x(3) & x(3)^2 & x(3)^3 & x(2) & x(2)^2 & x(2)^3\\
x(5) & x(5)^2 & x(5)^3 & x(4) & x(4)^2 & x(4)^3 & x(3) & x(3)^2 & x(3)^3\\
x(6) & x(6)^2 & x(6)^3 & x(5) & x(5)^2 & x(5)^3 & x(4) & x(4)^2 & x(4)^3\\
\end{matrix}\right]
[/tex]
However, in my experiments I found that this matrix is very unstable and has high condition numbers. No matter which "signal" x I plug into, even if the x are drawn from a Gaussian distribution.
Can anyone tell me why this matrix is so unstable or if I am doing something wrong?
The crazy thing is that the paper suggests the algorithm works without any problems (using the same parameter set) but I just can't reproduce this ...
Thanks,
div
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Jan17-13, 02:42 PM   #2
Recognitions:
Homework Helper Homework Help
Please clarify a couple of points:
1. Do you really mean under-determined? Over-determined means more rows than columns.
2. Does x(3)3 mean x * (33) or (x3)3? If the former, it means x is a scale factor for the entire matrix. If the latter, it means the matrix is generated from 6 values.
Jan17-13, 03:30 PM   #3
Quote by hotvette View Post
Sorry, I was not clear enough. It is indeed over-determined. Better clarification:
[tex]
\vdots & \vdots & \vdots & \vdots & \vdots & \vdots & \vdots & \vdots & \vdots \\
x(N) & x(N)^2 & x(N)^3 & x(N-1) & x(N-1)^2 & x(N-1)^3 & x(N-1) & x(N-1)^2 & x(N-1)^3\\
\end{matrix}\right]
[/tex]
with N>>3.
It means the latter. [itex]x(n)[/itex] is a sequence where n is the nth value of the sequence.
It appears that this matrix has a similar structure than a Vandermonde but not quite.
Vandermonde matrices seem to have high condition numbers and to be instable. Yet, they seem to be used quite frequently, also in Engineering papers I found Vandermonde matrices which are just solved "by the MATLAB backslash operator" (Moore Penrose pseudo inverse).
Thanks
Jan17-13, 03:48 PM   #4
Math 2012
Recognitions:
Quote by divB View Post
Thanks
AFAK the MATLAB backslash operatior is not the same as the Moore pensore psendo inverse. http://www.mathworks.co.uk/help/matl...operators.html
But the QR method MATLAB uses should be work pretty well for that type of matrix. Are you trying to solve it that way, or doing something else?
Forming the normal equations by doing ##U^Tz = U^T U a## and then solving for ##a## would be an ill-conditioned disaster, unless N is small.
Jan17-13, 04:43 PM   #5
Quote by AlephZero View Post
I know.
I used pinv(U)*z as well as U \ z.
The thing is that in some publications it is even (implicitely) stated that they solved with the backslash operator.
New Reply
Thread Tools
Similar Threads for: Why is this matrix bad conditioned?
Thread Forum Replies
How to handle an ill-conditioned matrix? Linear & Abstract Algebra 1
Please help me to solve ill-conditioned linear system of matrix Linear & Abstract Algebra 0
well conditioned matrices General Engineering 2
