Low cost buck regulator - 12v in - 5v@2A & 6.5V@1A out
  • Thread starter Thread starter memoguy
    12v Regulator
A user is seeking a low-cost power regulation solution to convert 12V input into 5V at 2A and 6.5V at 1A. They initially considered using two specific switching regulators but found the total cost to be $40 and are unsure about paralleling them. Suggestions point towards the LM2596 buck converter as a viable alternative, noted for its affordability and suitability for the required outputs. There is uncertainty regarding the adjustment of voltage outputs, with a reference to using a trim pot for configuration. The discussion emphasizes the need for a cost-effective and easy-to-implement solution.
memoguy
Hi all!
I am looking for a low cost power regulation solution. Simply put, I need to be able to give a system 12v and get outputs of 5V@2A and 6.5V@1A.
I was thinking of using two of these with the output in parallel:
http://australia.rs-online.com/web/p/switching-regulators/6727124/
And two of these with the output in parallel:
http://australia.rs-online.com/web/p/switching-regulators/6727089/
But that would end up costing $40 and I am not even sure if you can put switching regulators in parallel like that.
So, I am looking for a lower cost solution that is easy to implement. It would be ideal if the components could be bought at RS or Jaycar.
Any ideas?
BUMP
Is any anyone able to offer any help?
memoguy said:
... and I am not even sure if you can put switching regulators in parallel like that.
I would think you cannot simply parallel them.
Looking back over past posts at the buck converters previously mentioned in construction projects, I note that vk6kro has referred to the LM2596. If price is a good indicator, it looks okay to me! http://www.ebay.com.au/sch/i.html?_nkw=LM2596[/color]
I'd need to check the technicalities closer, but with 12V in, you are wanting –5V out? Also, +6.5V?
The LM2596 looks good. I am wanting +5v & +6.5v out.
I am not certain how I would define the voltage output. I am thinking I adjust that trim pot.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
