Escape Velocity Calculation for a Spaceship in Space
The escape speed of a spaceship fired in space, at the same distance from the Sun as Earth, can be calculated using the formula V_e = (2GM/r)^0.5. The mass (M) to use in the calculation is the mass of the Sun, while the radius (r) is the distance from the Sun, approximately 150 million kilometers. This distance includes the Sun's radius plus the distance from the Earth to the Sun. The discussion confirms that this distance is the correct value for r in the escape velocity equation. Understanding these parameters is crucial for accurately calculating the escape speed.
athymy
What is the escape speed of a spaceship fired in space, far away from Earth but at the same distance from the sun as the Earth.
Ve = (2GM/r)^0.5
The problem is that I don't know what the M or r is since it is fired from space... Should I just assume that the mass is the suns and for r I just add the suns radius with the distance from the Earth to the sun?
Ve = (2GM/r)^0.5
The problem is that I don't know what the M or r is since it is fired from space... Should I just assume that the mass is the sun's and for r I just add the suns radius with the distance from the Earth to the sun?
How far is Earth from the Sun ?
That's how far the spaceship is from the Sun .
Ahh, so Earth is approx. 150,000,000 km from the sun so is that my r value?
Yes. Sure it is.
Dick said:
Yes. Sure it is.
Thanks for your help! :D
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
