Uniformly charged disk and the E field some distance Z from the center
The discussion revolves around a problem involving a uniformly charged disk and the electric field at a distance z from its center. Participants are exploring how the electric field behaves as the distance z increases, with some uncertainty about the mathematical treatment of the problem.
  • Participants discuss the equation for the electric field and the need for a binomial expansion to analyze the behavior of the field as z increases. There are questions about the manipulation of terms in the equation, particularly regarding the factorization of z in the denominator.
The discussion is ongoing, with some participants offering corrections to the equation and suggesting that the electric field decreases as 1/z. However, there is a disagreement about the correctness of this conclusion, indicating that further examination of the binomial expansion is needed.
Participants are operating under the assumption that the disk behaves like a point charge at large distances, but there is uncertainty about the mathematical steps leading to this conclusion.
anban
Hi,
I have a problem that describes a uniformly charged disk and the electric field a distance z from the center.
I have found an equation that describes the E field at any point z already. Now I have to find out how the E field decreases as z increases-- as 1/r^2, I assume, but I am not sure.
E = 2[itex]\pi[/itex]kσz(1-[itex]\frac{z}{\sqrt{z^{2}+R^{2}}}[/itex]) where R is the radius of the disk and z is the distance away from the disk.
I know I have to do a binomial expansion of (R/z). I think I am having mathematical issues rather than physical issues.
Before the expansion, I need to get some term (R/z). Does taking out a z^{2) from the denominator leave a z^{4} out front? Or a z^{3} out front? If I can figure this out then I know the rest.
##\sqrt{z^2+R^2} = \sqrt{z^2(1+(R/z)^2)}## and ##\sqrt{(a b)} = \sqrt{a}\sqrt{b}##
I believe you must have a typo in this expression. The dimensions on the right do not match the dimensions of electric field.
Good catch: The expression should be E = 2[itex]\pi[/itex]kσ(1-[itex]\frac{z}{\sqrt{z^{2}+R^{2}}}[/itex]).
So, the denominator of the last term can be rewritten as z[itex]\sqrt{1-(R^{2}/z^{2})}[/itex]. After a binomial expansion, I got that the E field decreases as 1/z.
I don't think that's correct. Check your binomial expansion simplification. Your original idea that the disk should behave as a point charge for large distances is right.
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 17 ·
