Register to reply
Converting uniformly distributed load applied to a surface on an angle to point loads
by tmglynch
Tags: angle, distributed, force, load
Share this thread:
tmglynch
#1
Jan24-13, 01:36 AM
P: 1
If there is a uniformly distributed load due to gravity on a truss, how do I convert this into point forces on the three pin joints on the truss?
I am having trouble trying to work it out as I'm pretty sure there will be both forces in the x and in the y for each of the joints, but I can't work out how to determine this.
Thanks
Phys.Org News Partner Engineering news on Phys.org
Student develops filter for clean water around the world
Developing the next evolution in underwater communication
Compact vibration harvester power supply with highest efficiency opens door to "fix-and-forget" sensor nodes
AppleBite
#2
Jan24-13, 06:47 AM
P: 54
Have you tried calculating the resultant force of the distributed force (which by the looks of your drawing will be at the middle joint, in the -y direction) and then calculated the forces in each truss due to the resultant force?
Remember, the moment caused by a distributed force can be expressed as a single resultant force applied at a point.
Register to reply
Related Discussions
Beam bending under a uniformly distributed load Engineering, Comp Sci, & Technology Homework 1
Point load Vs Distributed loads Mechanical Engineering 1
Bending moment query re. uniformly distributed load and concentrated load(s) Engineering, Comp Sci, & Technology Homework 1
Why does the charge uniformly distributed on the surface of the sphere only? Introductory Physics Homework 2
Uniformly Varying Load/Uniform Load to Concentrated Point Load Engineering Systems & Design 4
