Logic - clarification needed about implication
  • Thread starter Thread starter autodidude
    implication Logic
In logic, the implication P→Q is considered true when P is false, regardless of the truth value of Q. This is because the statement does not provide information about Q when P is not true, making it logically consistent. Similarly, when both P and Q are false, P→Q is still defined as true to maintain logical coherence across all truth combinations. The definitions ensure that logical implications function correctly, aligning with the principle that "if P is true, then Q must be true." Thus, the truth table for P→Q aligns with the contrapositive (not Q)→(not P), reinforcing the validity of these logical statements.
autodidude
If P→Q, and P is false but Q is true, then why is P→Q true? To me, it seems as though we shouldn't be able to do proceed because there isn't enough information. Same goes when P and Q are both false, how does that suggest P→Q is true?
Mathematics news on Phys.org
"If it rains, the street gets wet"
This statement is true, even if I spill water on the street (without rain).
More general: It cannot be false, if it does not rain. It just does not give any information about the street in that case.
Another reason for those definitions is so that logic "works" the way it should, for every combination of "true" and "false".
For example, "P implies Q" means the same (in ordinary English) as "if P is true, then Q is true", which means the same as "if Q is false, then P is false".
So the truth table for P→Q must be the same as for (not Q)→(not P),
That means P→Q must be defined as true, when P and Q are both false.
You can create a similar argument to show how P→Q must be defined with P is false and Q is true.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
