What Region of Operation Is a BJT In Given These Terminal Voltages?
  • Thread starter Thread starter hogrampage
    Bjt
The discussion revolves around determining the operating region of a BJT based on given terminal voltages. The user struggles with the concepts and initially guesses the regions but receives feedback indicating that only 2 out of 5 guesses were correct. Key regions discussed include cutoff, saturation, and active, with specific voltage conditions outlined for each region. The importance of calculating Vce correctly from the given voltages is emphasized, as it influences the classification of the BJT's operation. Ultimately, clarification on the definitions and graphical representations of these regions aids in understanding the correct answers.
hogrampage
The terminal voltages to ground are measured on a particular BJT. In what region does the device operate if these terminal voltages are equal to the following values:
a) Vc = 6V, Vb = 0.6V, Ve = 0V
b) Vc = 6V, Vb = 2V, Ve = 1.4V
c) Vc = 6V, Vb = 6V, Ve = 5.4V
d) Vc = 6V, Vb = 4V, Ve = 3.6V
e) Vc = 3.6V, Vb = 4V, Ve = 3.4V
No idea which equations apply to this.
I sort of just guessed because I honestly have no idea:
a) Cut-off
b) Constant current
c) Constant Current
d) Constant Current
e) Saturation
I don't know why, but I am having a hard time understanding some of the concepts in the book we are using (Microelectronic Circuits and Devices 2nd, Horenstein) so these problems are giving me trouble. The book seems to be really vague.
I would first need to know how your text defines the different regions. Do they show a graph of i on the y-axis vs. Vce on the x-axis and then define the various regions?
Yes, they do I on y-axis and Vce on x-axis.
Do they superimpose a piecewise-linear graph on top of one or more of the i-V curves? And is the family of curves for various values of Vbe or ib?
I've attached an image of the graph shown in the book.
OK, so there are just three regions : cutoff, saturation and active.
So - how about looking carefully at the graph and making your decisions? BTW there are no numbers given on your graph but assume that "saturation" implies Vbe > Vce and "cutoff" implies Vbe < 0.6V. Make your choices & I'll help you if needed.
Keep in mind that all the voltages given are with respect to "ground". So for example in case (b), Vce = 6 - 1.4 = 4.6V, not 6V.
EDIT: not to spoil your day, but you got only 2 out of 5 right so far. :redface:
Here's what I came up with:
a) Constant current (Vce > Vbe)
b) Constant current (Vce > Vbe)
c) Saturation (Vce = Vbe)
d) Cutoff (Vbe < 0.6)
e) Saturation (Vce < Vbe)
OK except possibly for (c). I say "possibly" because here Vce = Vbe puts us right on the borderline between active and saturation. (Actually most people would consider that saturation.) So you have done well unless you were just lucky ...
