Maximum photocurrent in photoelectric effect
The maximum photocurrent in the photoelectric effect is influenced by the energy of incident photons, which varies with the wavelength of light. Yellow light (580 nm) has lower energy compared to green (546 nm) and blue (404 nm) light, resulting in a lower maximum photocurrent. While theory suggests that maximum photocurrent should not depend on wavelength, experimental results demonstrate variations due to the sensitivity of materials to different wavelengths and the intensity of light. Thus, both photon energy and material properties significantly impact photocurrent outcomes.
  • Understanding of quantum theory related to the photoelectric effect
  • Knowledge of photon energy and wavelength relationships
  • Familiarity with experimental setups for measuring photocurrent
  • Insight into material properties affecting photoelectric responses
  • Research the relationship between photon energy and wavelength in quantum mechanics
  • Explore the characteristics of different materials used in photoelectric experiments
  • Study the impact of light intensity on photocurrent measurements
  • Investigate advanced theories explaining discrepancies in experimental results
Physicists, materials scientists, and educators interested in the practical applications and theoretical foundations of the photoelectric effect.
J-F
I would like to know why, experimentaly, there is a difference between the maximum photocurrent with a yellow illumination (lambda = 580 nm) and other colors with a lower wavelenght like green or blue, respectively 546 and 404 nm. According to the theory, the max photocurrent does not depend of the wavelenght of the illumination
Thanks
Originally posted by J-F
According to the theory, the max photocurrent does not depend of the wavelength of the illumination
Don't know what theory you refer to, but it's certainly not quantum theory. Because quantum theory states that longer-wavelength radiation consists of photons with lower energy. Which thus have a smaller chance to kick an electron out of the photoconductor's surface. See here:
http://www.colorado.edu/physics/2000/quantumzone/photoelectric.html
for your question. The maximum photocurrent in the photoelectric effect is determined by the energy of the incident photons, not the wavelength. According to the theory, the maximum photocurrent should not depend on the wavelength of the illumination. However, in experiments, we often see a difference in the maximum photocurrent for different colors of light.
This can be explained by the fact that different colors of light have different energies. For example, yellow light has a longer wavelength and therefore a lower energy than green or blue light. This means that yellow light will not be able to eject electrons with as much energy as green or blue light, resulting in a lower maximum photocurrent.
Additionally, the materials used in the experiment can also play a role in the difference in maximum photocurrent. Some materials may have a higher sensitivity to certain wavelengths of light, resulting in a higher maximum photocurrent for those colors.
It is also important to note that the maximum photocurrent is not the only factor that determines the efficiency of the photoelectric effect. Other factors such as the intensity of the light and the properties of the material can also affect the overall efficiency.
In conclusion, while the theory states that the maximum photocurrent should not depend on the wavelength of the illumination, in practice, there can be variations due to the energy of the incident photons and the properties of the material used. It is important to carefully consider all factors when conducting experiments and interpreting results in the photoelectric effect.
10K
14K
  • · Replies 38 ·
24K
  • · Replies 21 ·
  • · Replies 74 ·
16K
