How to use the normal form of the Green's Theorem?
The discussion focuses on applying Green's Theorem to compute the flux integral of the vector field F, defined as the gradient of the scalar potential function f(x, y) = 1/2(x² + y²). The correct approach involves calculating the gradient F = ∇f, which yields F(x, y) = (x, y). The flux integral over the positively oriented unit circle C, parametrized by r(t) = (cos t, sin t), results in a value of 2π, confirming the application of the theorem. The initial incorrect attempt involved misidentifying the components of F, leading to an erroneous result of 0.
  • Understanding of Green's Theorem and its application in vector calculus.
  • Knowledge of scalar potential functions and their gradients.
  • Familiarity with parametrization of curves, specifically the unit circle.
  • Ability to compute partial derivatives of functions of multiple variables.
  • Learn how to compute the gradient of scalar functions in multivariable calculus.
  • Study the applications of Green's Theorem in various contexts, including flux integrals.
  • Explore examples of parametrizing different curves in the plane.
  • Investigate the relationship between line integrals and double integrals in vector fields.
Students studying vector calculus, particularly those learning about Green's Theorem, as well as educators and tutors seeking to clarify concepts related to flux integrals and scalar potential functions.
randomcat
Suppose that F = ∇f for some scalar potential function f(x, y) = 1/2(x2 + y2)
Let C denote the positively oriented unit circle, parametrized by r(t) = (cos t, sin t), 0 ≤ t ≤ 2∏. Compute the flux integral of [itex]\oint[/itex]F[itex]\bullet[/itex]N ds, where N is the outward unit normal to C.
I know that the theorem is basically [itex]\oint[/itex]F[itex]\bullet[/itex]N ds = double integral of ([itex]\frac{\partial M}{\partial x}[/itex] + [itex]\frac{\partial N}{\partial y}[/itex]) dx dy
My question is, how do you find F(x, y)? I'm given f(x, y) in the problem, but do I need to use it to solve for the answer?
What I did (which was wrong) was that I set M = 1/2x2 and N = 1/2y2 and took the partial derivatives of those. That gives me (x, y). With the parametrization, I get (cos t, sin t). Then I integrate them over the unit circle and got 0, which was wrong. The correct answer is 2pi.
My professor wrote that F = ∇f = F(x, y) in the solutions, but where did F(x, y) come from?
You are given ##f=(x^2+y^2)/2## and ##F=\nabla f##. So calculate ##\nabla f## to get ##F##.
Perhaps the problem is that you don't know what [itex]\nabla f[/itex] means? If f is as function of two variables, x and y, the [itex]\nabla f[/itex] is the vector function
[tex]\frac{\partial f}{\partial x}\vec{i}+ \frac{\partial f}{\partial y}\vec{j}[/tex]
That should be easy to calculate for this f.
