Cat 5 Digital Audio: Transmit/Receive 12 Channels @ 48KHz
  • Thread starter Thread starter jordanstreet
    Audio Digital
This discussion focuses on transmitting and receiving 12 channels of 24-bit audio at 48KHz over distances of 100 to 300 feet using Cat 5 cable. The proposed configuration includes differential signaling with twisted pairs for power, clock, transmit, and receive lines. The bandwidth requirement is calculated at 13.824 MHz, exceeding the RS-485 specification of 10 MHz at 40 feet. The recommendation is to utilize 100Base-T transceivers on a doubly terminated bus to achieve the necessary bandwidth.
  • Understanding of differential signaling in audio transmission
  • Familiarity with Cat 5 cable wiring and twisted pair configurations
  • Knowledge of RS-485 specifications and limitations
  • Experience with 100Base-T networking and PHY ICs
  • Research the implementation of 100Base-T transceivers for audio applications
  • Learn about asynchronous communication protocols for microprocessor and FPGA integration
  • Explore techniques for eliminating signal reflection in high-speed data transmission
  • Investigate existing PHY ICs suitable for audio data transmission over Cat 5 cable
Audio engineers, network engineers, and developers working on digital audio transmission systems who require knowledge of high-bandwidth networking solutions.
jordanstreet
Hey guys I'm hoping someone can point me in the right direction here. My goal is to receive 12 and transmit 4 channels of 24 bit audio @ 48KHz over 100ft to 300ft. I would guess that at this distance I need differential signals. The Cat 5 cable would then have the following twisted pairs
1) Vcc and Gnd
2) Clk + and -
3) Transmit + and -
4) Receive + and -
Given the receive of 12 channels being the limiting case: 12 * 24 * 48000 = 13.824 MHz would appear to be the bandwidth requirement of this situation. The RS-485 spec states that the max bandwidth @ 40ft is only 10 MHz.
I know this sort of thing is possible as I've seen it all the time in digital snakes, etc. Any help would be greatly appreciated!
Thanks!
Jordan
1) Vcc and Gnd
2) Clk + and -
3) Transmit + and -
4) Receive + and -
Thanks!
Jordan
RS-485 is a multi-drop network spec. Use 100Base-T transceivers on a point-to-point doubly terminated bus. That will give you plenty of bandwidth.
http://en.wikipedia.org/wiki/100BASE-T#Copper
:smile:
Hey berkeman, thank you for the speedy reply!
I took a look at that and it looks very promising. By doubly terminated, do you mean a resistor equal to the characteristic impedance at both the send and receive on each line to eliminate reflection?
It looks as though one option would be to implement the physical layer using an existing PHY IC, and then communicate from my microprocessor or fpga to the PHY through MII. Since there is no synchronous clock between devices on the 100mbit network it appears as though I would need to use some sort of asynchronous protocol between devices. Any thoughts how that might be accomplished?
Thank you again for the assistance!
