Question about precession in the case of frisbees
  • Context: Undergrad
  • Thread starter Thread starter Thundagere
    Precession
The discussion revolves around the physics of frisbees, particularly focusing on the phenomenon of precession and its role in the behavior of a frisbee when thrown at an angle towards the ground. Participants explore the mechanics involved in the frisbee's motion, including the effects of torque and angular momentum during its interaction with the ground.
  • One participant describes the frisbee's behavior as a result of precession, questioning how the angular momentum and torque interact when the frisbee hits the ground at an angle.
  • Another participant argues that the frisbee's upward motion is primarily due to bouncing off the ground rather than precession.
  • A participant elaborates on the mechanics of the frisbee's rotation and the resulting torque from the normal force, suggesting that this leads to a precession that causes the frisbee to pitch upwards.
  • There is a mention of the effects of camber on the frisbee, indicating that it typically experiences a pitch down torque, which is somewhat counteracted by the center of lift being in front of the center of mass.
  • A reference is provided to a website that explains the relationship between the vectors involved in gyroscopic effects, which some participants find helpful.
  • Another participant introduces the concept of a flying ring, suggesting that it can be designed to avoid rolling during flight, contrasting it with the behavior of a frisbee.
Participants express differing views on the primary cause of the frisbee's upward motion, with some attributing it to precession and others to the bouncing effect. The discussion remains unresolved regarding the relative contributions of these factors.
There are unresolved aspects regarding the interplay between precession and bouncing, as well as the specific conditions under which these effects manifest in frisbee flight.
Thundagere
So, I was trying to figure out the physics of frisbees. When you throw a frisbee at the ground at an angle (such that the side to the left of you, assuming you are right handed, hits the ground first), then it will suddenly skip up and fly upwards (Youtube has some great videos of it, for anyone who hasn't seen this). Someone told me this was because of precession. How does this work?
Precession is the phenomenon where the angular momentum changes in the direction of a net torque, correct? In this case, we have an upward normal force, so a torque horizontal to the ground going away from the thrower on the edge of the frisbee. The angular momentum vector is, of course, through the axis of rotation. They're almost 90 degrees to each other, so how would precession work in this case to flip the frisbee up?
Thanks for any help!
The frisbee is just bouncing off the ground, the same as any semi-elastic colliision. Precession also occurs, but almost all of the change in direction from the ground is due to bouncing.
Exactly.
From above the frisbee is rotating clockwise, so the rotation vector of the frisbee points down.
The normal attempts to twist the axis of rotation of the frisbee clockwise from your perspective.
So you have a torque vector from this normal pointing away from you.
From that you can deduce the direction of the resulting precession vector which will cause the frisbee axis of rotation to change direction and cause it to what looks like a skip and fly upwards.
Here is a site that explains how the three vectors are related:
http://www.motivate.maths.org/content/wonderful-world-gyroscopes/gyroscopic-effect
256bits, thanks for that website reference! One of the better explanations I've ever seen!
256bits said:
From above the frisbee is rotating clockwise, so the rotation vector of the frisbee points down. The normal attempts to twist the axis of rotation of the frisbee clockwise from your perspective. So you have a torque vector from this normal pointing away from you.
So the result is a pitch upwards of the frisbee, causing it to climb, but there is an initial bounce, and I wasn't sure if you were asking about the bounce or the tendency to climb afterwards.
Also, for a cambered airfoil like a frisbee, there's a pitch down torque. This is somewhat compensated for by having the center of lift in front of the cetner of mass, but generally it's a pitch down torque, that results in a roll reaction (precession) during longer flights.
A flying ring, such as an aerobie, solves this problem and can be "tuned" so that it does not roll during long flights.
http://aerobie.com/about/ringscientificpaper.htm
  • · Replies 39 ·
  • · Replies 19 ·
