How to choose Hfe in common emmiter amplifier circuit
  • Thread starter Thread starter null void
    Amplifier Circuit
When constructing a common emitter amplifier circuit using the BC107bp transistor, it's essential to choose the appropriate Hfe value based on the collector current. For a collector current of 1mA, selecting an Hfe of 200 is advisable, as it provides a balance between performance and stability. The choice of Hfe can significantly impact the amplifier's frequency response and input impedance, depending on the configuration used. Conducting a worst-case analysis is recommended for design engineering, while beginners should start with average values and explore parameter extremes for educational purposes. Understanding these variations is crucial for effective circuit design.
null void
I am using a transister model BC107bp in multisim, and i found that its min Hfe is 40 and max Hfe is 450. If I want to construct an amplifier circuit, i should choose the min or average? I found most of the datasheet show the hfe of collector current at 2m A (min 200 - max 450), but if my collector current is 1mA, should i choose the min Hfe which is 40? Any suggestion?
It depends on the amplifier configuration.
If it is a common emitter amplifier then high frequency response will be hurt by a high Hfe.
If it is a common base amp it will not be sensitive to Hfe variation.
If it is common collector, (emitter follower), then input impedance will be affected by Hfe variation.
Design engineering requires that you perform a worst case analysis where all parameters vary. A student or hobbyist should start modelling with average values, then test some parameter extremes as a learning exercise. Explaining the changes observed with parameter changes will be highly educational.
Likes 1 person
For the Ic = 1mA you shoudl choose hfe = 200.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
