Metrics for the Sun & Earth: Rs & Assumptions
Philosophaie
Is there a Metric for the Sun and Earth other than the Schwarzschild Metric who has the Schwarzschild Radius on the interior of the body?
What are the assumptions that turn that from GR to Newtonian?
Rs(Earth)=8.87*10^-3m
Rs(Sun)=2954m
The Schwarzschild radius is outside the body pretty much by definition... though you can see where the Schwarzschild radius would be if all the matter were concentrated at the center ... but that is always inside the body for objects less massive than black holes. So I think you need to be a bit more precise about what you mean.
It is probably possible to produce a metric which has a coordinate singularity anywhere you like.
Rs(Sun)=2954m
As you point out, the Schwarzschild radii for the Earth and Sun are inside the physical bodies. But that is not a problem because the exterior Schwarzschild solution applies to any spherically symmetric static( stationary?) spacetime.
If the spatial curvature is ignored and all velocities << c, and r>>m one can recover the Newtonian equations.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
