Projectile Motion without Initial Velocity
A projectile is launched at a 50° angle and lands after 12 seconds, prompting calculations for its maximum height and range. The main challenge is determining the initial velocity (Vo), which is essential for solving the problem. A relevant formula is identified: V_y = V_o * Sin(θ) - gt, where V_y equals zero at the peak height. By finding the time when V_y equals zero, one can derive Vo using trigonometric relationships. This approach enables the calculation of both the maximum height and range of the projectile.
PerryKid
Projectile Motion without Initial Velocity (Only time and angle given)
A projectile is launched at an angle of 50° above the horizontal and it hits the ground in 12 seconds.
a. Calculate the maximum height of the projectile.
b. Find the range of the projectile.
H_{max}=\frac{V_{o}^{2}+sin^{2}\theta}{g}
R=V_{o}\sqrt{\frac{2H}{g}}
I don't know where to start. I can't solve without Vo and I am missing Vo.
Can you not use a standard kinematic equation to get vy0?
I need [STRIKE]Vo to find height and range, not Vyo[/STRIKE]
EDIT: I found a formula to help me solve it all! :approve:
V_{y}=V_{o}Sin(\theta)-gt
V_{y}=0
But if you can find vy0, then you can find v0 with some simple trig.
V_{y}=0
That will work. At what t will vy = 0?
