Calculating Boltzmann's Constant (k) with h=6.6E23
  • Thread starter Thread starter PStudent111
    Constant
To calculate Boltzmann's constant (k) using Planck's constant (h=6.6E23), the equations E = kT and E = hv are utilized. The approach involves substituting E with hv and rearranging to express k in terms of h, wavelength (lambda), and temperature (T). The discussion indicates confusion at the step of isolating k, particularly when relating frequency and wavelength. The final goal is to demonstrate that k equals 0.71 cm-1 deg-1. Clarification on the calculations and units is needed to reach the correct conclusion.
PStudent111
Using h=6.6E23, show that k (Boltzmann constant) = 0.71 cm-1 deg-1? (
E = kT
E = hv
The only approach I can think of is:
1. E = hv
2. kT = hv
3. k = hv/T
4. Since v = c/lambda, k = hc/(lambda)T
But, I am stuck at the step above...
h=6.6E23
sure
I believe it's
E = kT = hf = (hc)/\lambda
then
1/(T\lambda)=k/(hc)
janhaa said:
h=6.6E23
sure
E-34, my bad
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
